03-26-2015, 19:32 | #1 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 355303 Status: Offline Thanks Meter: 7 | S5 G900h IMEI [Solved] imei 004 after flash i try repair but nothing happen --------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900H Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900H Firmware compiled date: Tue Jan 20 11:47:20 KST 2015 PDA version: G900HXXU1BOA7 CSC version: G900HOXY1BOA7 SW version: G900HXXU1BOA7 Last edited by Octopus box; 03-27-2015 at 07:11. |
03-26-2015, 19:55 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Currently no solution for phones on Android 5.x. You should downgrade it to Android 4.4.x version and then You will be able to write Cert file. |
03-26-2015, 22:17 | #4 (permalink) |
Member: 355303 Status: Offline Thanks Meter: 7 | all done thanx octopus team Welcome to Octoplus/Octopus Box Samsung software version 1.8.9 ----------------------------------------------------------------------------------- To connect SM-G900H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900H Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900H Firmware compiled date: Mon Mar 31 14:30:57 KST 2014 PDA version: G900HXXU1ANCI CSC version: G900HOJV1ANCH SW version: G900HXXU1ANCI Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. 4. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM754 Phone connected successfully Writing new phone IMEI... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
The Following User Says Thank You to mena_ishak For This Useful Post: |
