10-12-2016, 13:05 | #1 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | S5 mini not dialing out I have S5 mini - IMEI is clean / not blacklisted Handset says dialing but does not ring out. Handset has been flashed by samsung smart switch and I have tried many sim cards.. Any Solution for this issue |
10-14-2016, 09:05 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Android 5.1.1 firmwares for SM-G800F are now available in the Support Area. |
10-20-2016, 12:08 | #7 (permalink) |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Welcome to Octoplus/Octopus Box Samsung software version 2.3.7 ----------------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Press Home button. 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G800F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: G800FXXU1BPE3_G800FDBT1BPE3 _DBT_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G800F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... Writing Firmware Failed Performed by 2.3.7 Software version. |
10-20-2016, 12:50 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please repeat "Write Firmware" operation with enabled "Advanced Mode" option and un-check "HIDDEN" partition in process. |
