11-10-2014, 10:24 | #3 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Algérie Age: 45
Member: 2269857 Status: Offline Thanks Meter: 364 | hello you ned flashe your phone Welcome to Octoplus/Octopus Box Samsung software version 1.7.0 ----------------------------------------------------------------------------------- To connect SM-G900H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: G900HXXU1ANE2_G900HOJV1AND4 _G900HXXU1ANE2_HOME.oct Please put the phone into Download Mode and connect USB cable. To put SM-G900H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed |
