06-03-2015, 00:50 | #1 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 209047 Status: Offline Thanks Meter: 7 | S5 SM-G900h imei repair fails at uart [Solved] Last edited by Octopus box; 06-03-2015 at 16:16. |
06-03-2015, 13:55 | #3 (permalink) |
Member: 209047 Status: Offline Thanks Meter: 7 | INFO : 6/2/2015 6:31:36 PM > Platform: Samsung Android INFO : 6/2/2015 6:31:36 PM > Selected port: COM195 INFO : 6/2/2015 6:31:37 PM > Selected model: SM-G900H INFO : 6/2/2015 6:31:37 PM > Searching for a phone. Please wait... WARN : 6/2/2015 6:31:38 PM > Please, press "OK" button on the phone to allow USB debugging.. INFO : 6/2/2015 6:31:43 PM > Phone found. INFO : 6/2/2015 6:31:46 PM > Firmware compiled date: Tue Jan 20 11:47:20 KST 2015 INFO : 6/2/2015 6:31:46 PM > PDA version: G900HXXU1BOA7 INFO : 6/2/2015 6:31:47 PM > CSC version: G900HOXY1BOA7 INFO : 6/2/2015 6:31:48 PM > SW version: G900HXXU1BOA7 INFO : 6/2/2015 6:31:49 PM > Phone IMEI: Unknown INFO : 6/2/2015 6:31:49 PM > Phone SN: 00000000000 INFO : 6/2/2015 6:31:49 PM > Android version: 5.0 (LRX21T) INFO : 6/2/2015 6:35:28 PM > ----------------------------------------------------------------------------------- INFO : 6/2/2015 6:35:29 PM > Platform: Samsung Android INFO : 6/2/2015 6:35:29 PM > Selected port: COM195 INFO : 6/2/2015 6:35:29 PM > Selected model: SM-G900H ERROR : 6/2/2015 6:35:29 PM > Please select service IMEI for this phone model ERROR : 6/2/2015 6:35:29 PM > Write IMEI failed INFO : 6/2/2015 6:36:01 PM > ----------------------------------------------------------------------------------- INFO : 6/2/2015 6:36:02 PM > Platform: Samsung Android INFO : 6/2/2015 6:36:02 PM > Selected port: COM195 INFO : 6/2/2015 6:36:02 PM > Selected model: SM-G900H ERROR : 6/2/2015 6:36:05 PM > Proper android device not found. Make shure that "USB debug" option on the device is turned on. ERROR : 6/2/2015 6:36:05 PM > Write IMEI failed INFO : 6/2/2015 6:36:10 PM > ----------------------------------------------------------------------------------- INFO : 6/2/2015 6:36:12 PM > Platform: Samsung Android INFO : 6/2/2015 6:36:12 PM > Selected port: COM195 INFO : 6/2/2015 6:36:12 PM > Selected model: SM-G900H INFO : 6/2/2015 6:36:14 PM > Detected phone model: SM-G900H INFO : 6/2/2015 6:36:14 PM > Firmware compiled date: Tue Jan 20 11:47:20 KST 2015 INFO : 6/2/2015 6:36:14 PM > PDA version: G900HXXU1BOA7 INFO : 6/2/2015 6:36:14 PM > CSC version: G900HOXY1BOA7 INFO : 6/2/2015 6:36:15 PM > SW version: G900HXXU1BOA7 INFO : 6/2/2015 6:36:16 PM > Phone IMEI: Unknown INFO : 6/2/2015 6:36:17 PM > Phone SN: 00000000000 INFO : 6/2/2015 6:36:17 PM > Android version: 5.0 (LRX21T) INFO : 6/2/2015 6:36:17 PM > Checking Root: INFO : 6/2/2015 6:36:22 PM > Phone is Rooted. INFO : 6/2/2015 6:36:22 PM > Reading security backup, please wait... WARN : 6/2/2015 6:37:12 PM > Phone will restart now. Please don't disconnect cable! WARN : 6/2/2015 6:38:22 PM > After phone being rebooted and powered on perform the following steps: WARN : 6/2/2015 6:38:22 PM > 1. Disconnect USB cable. WARN : 6/2/2015 6:38:22 PM > 2. Wait for 1-2 minutes. WARN : 6/2/2015 6:38:22 PM > 3. Connect phone via UART cable to the Box. WARN : 6/2/2015 6:38:22 PM > 4. Note: phone screen must be active INFO : 6/2/2015 6:38:22 PM > Connecting to phone, please wait... INFO : 6/2/2015 6:39:29 PM > IMEI successfully repaired. WARN : 6/2/2015 6:39:29 PM > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) INFO : 6/2/2015 6:41:39 PM > ----------------------------------------------------------------------------------- INFO : 6/2/2015 6:41:41 PM > Platform: Samsung Android INFO : 6/2/2015 6:41:41 PM > Selected port: COM49 INFO : 6/2/2015 6:41:41 PM > Selected model: SM-G900H ERROR : 6/2/2015 6:41:41 PM > Proper android device not found. Make shure that "USB debug" option on the device is turned on. ERROR : 6/2/2015 6:41:41 PM > Write IMEI failed INFO : 6/2/2015 6:42:12 PM > ----------------------------------------------------------------------------------- INFO : 6/2/2015 6:42:16 PM > Platform: Samsung Android INFO : 6/2/2015 6:42:16 PM > Selected port: COM49 INFO : 6/2/2015 6:42:16 PM > Selected model: SM-G900H ERROR : 6/2/2015 6:42:16 PM > Proper android device not found. Make shure that "USB debug" option on the device is turned on. ERROR : 6/2/2015 6:42:16 PM > Write IMEI failed INFO : 6/2/2015 6:42:55 PM > ----------------------------------------------------------------------------------- INFO : 6/2/2015 6:42:56 PM > Platform: Samsung Android INFO : 6/2/2015 6:42:56 PM > Selected port: COM49 INFO : 6/2/2015 6:42:56 PM > Selected model: SM-G900H INFO : 6/2/2015 6:43:03 PM > Detected phone model: SM-G900H INFO : 6/2/2015 6:43:03 PM > Firmware compiled date: Tue Jan 20 11:47:20 KST 2015 INFO : 6/2/2015 6:43:03 PM > PDA version: G900HXXU1BOA7 INFO : 6/2/2015 6:43:04 PM > CSC version: G900HOXY1BOA7 INFO : 6/2/2015 6:43:04 PM > SW version: G900HXXU1BOA7 INFO : 6/2/2015 6:43:06 PM > Phone IMEI: Unknown INFO : 6/2/2015 6:43:06 PM > Phone SN: 00000000000 INFO : 6/2/2015 6:43:06 PM > Android version: 5.0 (LRX21T) INFO : 6/2/2015 6:43:06 PM > Checking Root: INFO : 6/2/2015 6:43:07 PM > Phone is Rooted. INFO : 6/2/2015 6:43:07 PM > Reading security backup, please wait... WARN : 6/2/2015 6:43:57 PM > Phone will restart now. Please don't disconnect cable! WARN : 6/2/2015 6:47:39 PM > After phone being rebooted and powered on perform the following steps: WARN : 6/2/2015 6:47:39 PM > 1. Disconnect USB cable. WARN : 6/2/2015 6:47:39 PM > 2. Wait for 1-2 minutes. WARN : 6/2/2015 6:47:39 PM > 3. Connect phone via UART cable to the Box. WARN : 6/2/2015 6:47:39 PM > 4. Note: phone screen must be active INFO : 6/2/2015 6:47:39 PM > Connecting to phone, please wait... INFO : 6/2/2015 6:48:47 PM > IMEI successfully repaired. WARN : 6/2/2015 6:48:47 PM > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
06-03-2015, 14:17 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to write Certificate file from the Support Area and check IMEI. Post here results and Software log of performed operation. |
06-03-2015, 15:29 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | All cert files are available in "Samsung/FOR UNLOCK AND REPAIR/Certificates" folder of the Support Area. To enter Support Area, press "Go to support" button on "Support & options" tab of the Software. |
