07-22-2014, 17:15 | #1 (permalink) |
Insane Poster Join Date: Jun 2014
Member: 2204876 Status: Offline Thanks Meter: 6 | s5620 monte flash failed.. Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\22-07-2014_18-24-43.log" created (22.7.2014 18:24:47).ERROR : 22.7.2014 18:24:51 > Access violation at address 0092BFAC in module 'OctoplusSamsung.exe'. Read of address 00000004INFO : 22.7.2014 18:25:07 > Set up system language English (file: English.ini)INFO : 22.7.2014 18:25:07 > Welcome to Octoplus/Octopus Box Samsung software version 1.6.2INFO : 22.7.2014 18:25:07 > -----------------------------------------------------------------------------------INFO : 22.7.2014 18:25:07 > To connect SC-01C phone you have to perform the following steps: INFO : 22.7.2014 18:25:07 > 1. Disconnect USB cable from phone. INFO : 22.7.2014 18:25:07 > 2. Go to Menu->Settings->Applications->Development. INFO : 22.7.2014 18:25:07 > 3. Turn on "USB Debugging" option. INFO : 22.7.2014 18:25:07 > 4. When the message appears press "Yes". INFO : 22.7.2014 18:25:07 > 5. Connect USB cable to the phone. INFO : 22.7.2014 18:25:07 > 6. Press "Read Info" in software.INFO : 22.7.2014 18:26:07 > Selected firmware file: GT-S5620_FW_UNKN.octWARN : 22.7.2014 18:26:12 > Please put the phone into Download Mode and connect USB cable.WARN : 22.7.2014 18:26:12 > To put GT-S5620 into Download Mode, You have to perform the following steps: WARN : 22.7.2014 18:26:12 > 1. Reconnect the battery. WARN : 22.7.2014 18:26:12 > 2. Press and hold "Volume - " + "Camera" + "Power" keys.INFO : 22.7.2014 18:26:12 > Searching for a phone. Please wait...INFO : 22.7.2014 18:28:37 > Writing firmware CanceledWARN : 22.7.2014 18:32:19 > Please put the phone into Download Mode and connect USB cable.WARN : 22.7.2014 18:32:19 > To put GT-S5620 into Download Mode, You have to perform the following steps: WARN : 22.7.2014 18:32:19 > 1. Reconnect the battery. WARN : 22.7.2014 18:32:19 > 2. Press and hold "Volume - " + "Camera" + "Power" keys.INFO : 22.7.2014 18:32:19 > Searching for a phone. Please wait...INFO : 22.7.2014 18:32:34 > Writing firmware CanceledWARN : 22.7.2014 18:24:54 > Please put the phone into Download Mode and connect USB cable.WARN : 22.7.2014 18:24:54 > To put GT-S5620 into Download Mode, You have to perform the following steps: WARN : 22.7.2014 18:24:54 > 1. Reconnect the battery. WARN : 22.7.2014 18:24:54 > 2. Press and hold "Volume - " + "Camera" + "Power" keys.INFO : 22.7.2014 18:24:54 > Searching for a phone. Please wait...INFO : 22.7.2014 18:27:42 > Writing firmware CanceledWARN : 22.7.2014 18:27:45 > Please put the phone into Download Mode and connect USB cable.WARN : 22.7.2014 18:27:45 > To put GT-S5620 into Download Mode, You have to perform the following steps: WARN : 22.7.2014 18:27:45 > 1. Reconnect the battery. WARN : 22.7.2014 18:27:45 > 2. Press and hold "Volume - " + "Camera" + "Power" keys.INFO : 22.7.2014 18:27:45 > Searching for a phone. Please wait...INFO : 22.7.2014 18:28:02 > Found phone on COM4INFO : 22.7.2014 18:28:02 > Firmware write started.INFO : 22.7.2014 18:28:02 > Writing BOOT\BCMBOOT section...INFO : 22.7.2014 18:28:02 > Writing BOOT\BOOT2 section...INFO : 22.7.2014 18:28:03 > Writing BOOT\DROM_DSP section...INFO : 22.7.2014 18:28:03 > Writing BOOT\PATCH_DSP section...INFO : 22.7.2014 18:28:04 > Writing BOOT\SYSPARM_DEP section...INFO : 22.7.2014 18:28:04 > Writing BOOT\SYSPARM_IND section...INFO : 22.7.2014 18:28:04 > Writing BOOT\NVRAM6 section...WARN : 22.7.2014 18:28:04 > Phone will restart now. Please don't disconnect cable!INFO : 22.7.2014 18:28:19 > Writing AMSS section...INFO : 22.7.2014 18:28:30 > AMSS section has been written successfully.INFO : 22.7.2014 18:28:30 > Writing APPS section...INFO : 22.7.2014 18:29:49 > APPS section has been written successfully.INFO : 22.7.2014 18:29:49 > Writing RSRC1 section...INFO : 22.7.2014 18:30:55 > RSRC1 section has been written successfully.INFO : 22.7.2014 18:30:55 > Writing RSRC2 section...INFO : 22.7.2014 18:30:56 > RSRC2 section has been written successfully.INFO : 22.7.2014 18:30:56 > Writing FactoryFS section...INFO : 22.7.2014 18:30:56 > Formating FactoryFS partition...INFO : 22.7.2014 18:31:16 > Formating successfully compleatedERROR : 22.7.2014 18:32:39 > Writing Firmware FailedWARN : 22.7.2014 18:38:10 > Please put the phone into Download Mode and connect USB cable.WARN : 22.7.2014 18:38:10 > To put GT-S5620 into Download Mode, You have to perform the following steps: WARN : 22.7.2014 18:38:10 > 1. Reconnect the battery. WARN : 22.7.2014 18:38:10 > 2. Press and hold "Volume - " + "Camera" + "Power" keys.INFO : 22.7.2014 18:38:10 > Searching for a phone. Please wait...INFO : 22.7.2014 18:38:26 > Found phone on COM4INFO : 22.7.2014 18:38:26 > Firmware write started.INFO : 22.7.2014 18:38:26 > Writing BOOT\BCMBOOT section...INFO : 22.7.2014 18:38:26 > Writing BOOT\BOOT2 section...INFO : 22.7.2014 18:38:27 > Writing BOOT\DROM_DSP section...INFO : 22.7.2014 18:38:27 > Writing BOOT\PATCH_DSP section...INFO : 22.7.2014 18:38:28 > Writing BOOT\SYSPARM_DEP section...INFO : 22.7.2014 18:38:28 > Writing BOOT\SYSPARM_IND section...INFO : 22.7.2014 18:38:28 > Writing BOOT\NVRAM6 section...WARN : 22.7.2014 18:38:28 > Phone will restart now. Please don't disconnect cable!INFO : 22.7.2014 18:38:44 > Writing AMSS section...INFO : 22.7.2014 18:38:55 > AMSS section has been written successfully.INFO : 22.7.2014 18:38:55 > Writing APPS section...INFO : 22.7.2014 18:40:13 > APPS section has been written successfully.INFO : 22.7.2014 18:40:13 > Writing RSRC1 section...INFO : 22.7.2014 18:41:17 > RSRC1 section has been written successfully.INFO : 22.7.2014 18:41:17 > Writing RSRC2 section...INFO : 22.7.2014 18:41:18 > RSRC2 section has been written successfully.INFO : 22.7.2014 18:41:18 > Writing FactoryFS section...INFO : 22.7.2014 18:41:18 > Formating FactoryFS partition...INFO : 22.7.2014 18:41:38 > Formating successfully compleatedINFO : 22.7.2014 18:44:04 > FactoryFS section has been written successfully.INFO : 22.7.2014 18:44:04 > Writing CSC section...ERROR : 22.7.2014 18:44:37 > Writing Firmware Failed |
07-23-2014, 06:40 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | What was the problem with your phone exactly? Why you have decided to write another firmware? Try to do the next: 1. Fully charge phone's battery by using external charger. 2. Connect the device directly to PC motherboard USB port, don't use any USB hubs or PCI USB extention cards, this is important. 3. Put the phone into Emergency/Download Mode manually and try to write firmware again. 4. Post here the result. Also, try to write firmware on another PC. |
