10-22-2015, 13:47 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What exactly You mean by "not support"? Please look carefully in models list on "Qualcomm" tab. Also, You can go to "Support & options" tab of the Software, manually input "GT-S5660", then press Select. "Read Codes" and "Unlock" operations are supported for GT-S5660. |
10-22-2015, 15:01 | #3 (permalink) |
Freak Poster Join Date: Nov 2014 Location: madrid
Member: 2296854 Status: Offline Sonork: 100.1680516 Thanks Meter: 89 | Welcome to Octoplus/Octopus Box Samsung software version 2.0.7 ----------------------------------------------------------------------------------- To connect GT-S5660 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM11 Selected model: GT-S5660 Mode: Normal Phone model: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ]( Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM10 Detected phone model: GT-S5660 HW Version: GT-S5660DSATCL Phone IMEI: 351825-05-280386-8 Phone connection failed Connecting to phone on COM11 Mode: Normal Phone model: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ]( Phone model is not supported Phone connection failed No diagnostic ports found! Connecting to phone on COM10 Detected phone model: GT-S5660 HW Version: GT-S5660DSATCL Phone IMEI: 351825-05-280386-8 Detected phone model: GT-S5660 HW Version: GT-S5660DSATCL Phone IMEI: 351825-05-280386-8 Phone connection failed Connecting to phone on COM12 Phone connection failed |
10-22-2015, 15:27 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please reflash the phone with any 2.3.6 firmware from the Support Area, then try to connect the phone again. To connect the phone You have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Connect the phone directly to PC. 9. Press "Read Info" in software. |
