06-02-2015, 17:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2335578 Status: Offline Thanks Meter: 105 | S6 done by octopus box world first ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone.* 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N910A phone you have to perform the following steps: 1. Disconnect USB cable from phone.* 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-N910A Selected file: C:\Users\5STAR\Desktop\SAMSUNG-SM- G920A_R38G30JFMGY_3588430xxxxx_2-6-2015_0-45-46.cert Perform the following steps:* 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM23 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes |
The Following 5 Users Say Thank You to Isellcert For This Useful Post: |
