10-16-2018, 13:36 | #1 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | S6 edge (g925f) "cert" writed + unlock 100% Quote:
Br allumts | |
The Following 4 Users Say Thank You to allumts For This Useful Post: |
10-16-2018, 18:38 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | You can do this easy on G92xF [ both Galaxy S6 or S6 Edge European /Exynos5/ variants ] even binary 5 or 6 ... The phone do not check AP part downgrade. And it's more easy if you downgrade phone to 6.0.1 [ use just boot + recovery + system from AP part and cache from CSC ], leaving bootloader and CP part on binary 5 or 6 ... Then use preferred kernel for your version of Android OS [ 6.0.1 or 7.0 ] to achieve root rights [ in fact just correct patched boot image from AP part ] but flash CP from corespondent Combination FW [ depend you have binary 5 or 6 ] and play as you want ... EFS read / write, IMEI repair, Clean CERTIFICATE read / write [ you can use G920F, G925F, G920T, G925T, ect... certificate that you have without problem on any G92xF phone ], ect ... In fact - if you write clean certificate ... you do not need to perform UNLOCK - the phone will become UNLOCKED ... Just my 2 cents in additional to allumts tutorial if you like to service the S6 [and Edge] phones... When you "tune" all needed ... then you can update to latest OS WBR, DebeliaMark, BG Last edited by debeliamark; 10-16-2018 at 18:43. |
