04-19-2018, 14:12 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Ordu TÜRKİYE
Member: 1918391 Status: Offline Thanks Meter: 73 | S7 Edge SM-G935F cant locking pin gesture [Solved] Last edited by Octopus box; 06-11-2018 at 05:19. |
04-19-2018, 14:59 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to do Hard/Factory Reset and write different firmwares. |
04-19-2018, 16:33 | #3 (permalink) | |
Freak Poster Join Date: Aug 2016
Member: 2616438 Status: Offline Thanks Meter: 147 | Quote:
In the efs file you will find "factory*" folder responsible for this error Try reset ,repair or even write new efs will solve your problem | |
The Following 2 Users Say Thank You to wadda7o For This Useful Post: |
06-09-2018, 23:53 | #6 (permalink) |
Member: 1918391 Status: Offline Thanks Meter: 73 | This files not resloved http://efs.firmware.ir/wp-content/up...data-g935f.zip this phone's efs recovered by G935f combination file phone model G935FD http://forum.gsmhosting.com/vbb/f684...wered-2332766/ |
06-10-2018, 11:17 | #7 (permalink) |
Member: 1918391 Status: Offline Thanks Meter: 73 | FİNAL SOLUTİON: make backups before start 1. root phone (two level root method android 7 because data partititon) root steps a. flash twrp and ignore stuck boot until last zip flash b. flash supersu zip c. flash stock recovery d. format phone from recovery e. flash again twrp f. flash again super su zip 2. install root explorer 3. Inside the /efs folder, delete everything EXCEPT the 'FactoryApp' and 'prov_data' folders. 4. write nv backup. (maybe not required delete before nv_data.bin files) please add reset or repair efs button Last edited by gencom; 06-10-2018 at 11:24. |
The Following User Says Thank You to gencom For This Useful Post: |
06-10-2018, 12:46 | #8 (permalink) |
Member: 2616438 Status: Offline Thanks Meter: 147 | Not necessary to flash stock recovery in step c just format from twrp You could try the following solution try repair efs from model g925f will do the trick By the way your problem is in 'Factory App' folder |
The Following User Says Thank You to wadda7o For This Useful Post: |
06-10-2018, 17:29 | #9 (permalink) | |
Member: 1918391 Status: Offline Thanks Meter: 73 | Quote:
twrp cannot format data because cant mount before root. but problem resloved without error. one more qusestion. after repair and patch i want unroot and flash stock fw.. possible android 7 and 8. it works spd based j2 j3 unroot and clean possible for this s6 s7 s8 s9 like devices? | |
