06-03-2017, 21:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | s7 g930 f after installing noga 7 restart again and again flash again and again restart not go in recover but go in download when try to flash via other ver its suddenly restart again and again not accept any firmware even root file also not accept just tick to flash its reboot again and again Welcome to Octoplus/Octopus Box Samsung software version 2.5.4 ----------------------------------------------------------------------------------- To connect SM-G930F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: G930FXXU1DQAS_G930FOJV1DQAT_XSG.zip Selected BOOT file: E:\samsung 2\samsungs\g930f\uae 7.0 \BL_G930FXXU1DQAS_CL10273029_QB12269014_REV00 _user_low_ship.tar.md5 Selected AP file: E:\samsung 2\samsungs\g930f\uae 7.0 \AP_G930FXXU1DQAS_CL10273029_QB12269014_REV00 _user_low_ship_meta.tar Selected CP file: E:\samsung 2\samsungs\g930f\uae 7.0 \CP_G930FXXU1DQA3_CL10273029_QB12139038_REV00 _user_low_ship.tar.md5 Selected CSC file: E:\samsung 2\samsungs\g930f\uae 7.0 \CSC_OJV_G930FOJV1DQAT_CL10415117_QB12275417_REV00 _user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G930F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Performed by 2.5.4 Software version. |
06-06-2017, 07:42 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please try to write "G930FXXU1DQC4_G930FOJV1DQC6_XSG_Android_7" firmware from the Support Area and post here the result. |
06-09-2017, 07:41 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Firmwares for SM-G935FD are available in the Support Area. To access Support Area, press "Go to support" button on "Support & options" tab of the Software. Also You can use Files Downloader on "Support & options" tab of the Software to browse, search and download files from the Support Area. |
06-10-2017, 07:58 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please upload *.log and *.logx files of performed operations to any file-sharing service and post here download link. We will check what causes the problem. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
06-12-2017, 21:25 | #10 (permalink) | |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | in advance mode without sboot file done but phone same restart Quote:
----------------------------------------------------------------------------------- To connect SM-G930F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected BOOT file: F:\samsung 2\samsungs\g930f\uae 7.0\1 \BL_G930FXXU1DQC4_CL10422490_QB12768203_REV00 _user_low_ship.tar.md5 Selected AP file: F:\samsung 2\samsungs\g930f\uae 7.0\1 \AP_G930FXXU1DQC4_CL10422490_QB12768203_REV00 _user_low_ship_meta.tar Selected CP file: F:\samsung 2\samsungs\g930f\uae 7.0\1 \CP_G930FXXU1DQC2_CL443934_QB5909108_SIGNED.tar.md 5 Selected CSC file: F:\samsung 2\samsungs\g930f\uae 7.0\1 \CSC_OJV_G930FOJV1DQC6_CL10860517_QB12808415_REV00 _user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G930F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Performed by 2.5.4 Software version. Selected BOOT file: F:\samsung 2\samsungs\g930f\uae 7.0\1 \BL_G930FXXU1DQC4_CL10422490_QB12768203_REV00 _user_low_ship.tar.md5 Selected AP file: F:\samsung 2\samsungs\g930f\uae 7.0\1 \AP_G930FXXU1DQC4_CL10422490_QB12768203_REV00 _user_low_ship_meta.tar Selected CP file: F:\samsung 2\samsungs\g930f\uae 7.0\1 \CP_G930FXXU1DQC2_CL443934_QB5909108_SIGNED.tar.md 5 Selected CSC file: F:\samsung 2\samsungs\g930f\uae 7.0\1 \CSC_OJV_G930FOJV1DQC6_CL10860517_QB12808415_REV00 _user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G930F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CP_DEBUG section... CP_DEBUG section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.5.4 Software version. | |
