04-27-2014, 10:17 | #1 (permalink) |
Freak Poster Join Date: Sep 2010
Member: 1407087 Status: Offline Thanks Meter: 36 | S7262 white screen after root [Solved] when i write given root file in support and try to inter recovery i got a white screen and when i write another rom a wite screen will appear and mobile will not work (working fine Samsung sound will heard but screen still white) so i cant root it and cant repair imei i tried vroot and srsroot and all other root apps its just not working any help pleas Last edited by Octopus box; 05-05-2014 at 13:26. |
04-27-2014, 12:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Re-flash the phone with the firmware from the Support Area and then root the phone as it is written in Software manual ("Help" button in Software). |
04-27-2014, 17:15 | #3 (permalink) |
Member: 1407087 Status: Offline Thanks Meter: 36 | after flash mobile with S7262JVUAMI5_S7262OJVAMI4_S7262JVUAMI4_Android_4.1 .2.oct S7262XXUAMI4_S7262ODDAMI4_S7262XXUAMI4.oct but when finish flash i got "S7262 Logo" and after that screen get white it fixed when flash with DKR-S7262JVUANB2-20140401114124 by Odin Log: Selected firmware file: S7262JVUAMI5_S7262OJVAMI4_S7262JVUAMI4_Android_ 4.1.2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-S7262 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing PARAM section... PARAM section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing system section... system section has been written successfully. Writing modem section... modem section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ------------------------------------------------- Selected firmware file: S7262XXUAMI4_S7262ODDAMI4_S7262XXUAMI4.oct Please switch your phone to the download mode and connect it to a PC. To put GT-S7262 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing system section... system section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing modem section... modem section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Firmware writing successfully completed. ---------------------------------------------- Odin Log :: <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> S7262JVUANB2_S7262OJVANC2_S7262JVUANB1_HOME.tar.md 5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/015> Added!! <ID:0/015> Odin v.3 engine (ID:15).. <ID:0/015> File analysis.. <ID:0/015> SetupConnection.. <ID:0/015> Initialzation.. <ID:0/015> Get PIT for mapping.. <ID:0/015> Firmware update start.. <ID:0/015> sboot.bin <ID:0/015> NAND Write Start!! <ID:0/015> param.lfs <ID:0/015> boot.img <ID:0/015> recovery.img <ID:0/015> system.img <ID:0/015> modem.bin <ID:0/015> cache.img <ID:0/015> hidden.img <ID:0/015> RQT_CLOSE !! <ID:0/015> RES OK !! <ID:0/015> Removed!! <ID:0/015> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) ---------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM14 Selected model: GT-S7262 Reading info, please wait... Detected phone model: GT-S7262 Firmware compiled date: Wed Feb 19 18:18:27 KST 2014 PDA version: S7262JVUANB2 CSC version: S7262OJVANC2 SW version: S7262JVUANB1 Phone IMEI: 352833063****** Phone SN: R21F35C**** Android version: 4.1.2 (JZO54K) |
The Following 2 Users Say Thank You to khaled_wf7 For This Useful Post: |
04-28-2014, 06:47 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Ok, write the firmware after which the phone power on and root the phone. Try to find other root for this device and use it. |
04-28-2014, 08:51 | #5 (permalink) |
Member: 1407087 Status: Offline Thanks Meter: 36 | problem video : g u l f u p.com/?HhHlnu "remove space " i did that i wrote S7262JVUANB2 as you see at last , but i cant find any way to root it do yo have some idea or pre rooted S7262JVUANB2 maybe ?? |
04-29-2014, 19:25 | #6 (permalink) |
Insane Poster Join Date: Jun 2013
Member: 1953702 Status: Offline Thanks Meter: 3 | I have to change the imei of phone s7262. First I do root, but after that the screen turns white, I tried a lot of root programs but everytime I get the same white screen and nothing else. What can I do? |
04-30-2014, 06:29 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | It is necessary to find another root exploit, most likely, this root is not suitable to your phone's firmware. Currently we haven't got other root for this phone model. We will try to find other root exploit and, if we will find it, we will upload it into the Support Area. |
05-05-2014, 12:49 | #8 (permalink) | |
Freak Poster Join Date: Jul 2004 Location: Egypt-Alex
Member: 73117 Status: Offline Thanks Meter: 31 | Quote:
05-08-2014, 20:26 | #10 (permalink) | |
No Life Poster Join Date: Apr 2013 Location: Ordu TÜRKİYE
Member: 1918391 Status: Offline Thanks Meter: 73 | Quote:
not working this solution phone booting but recovery mode crashed. Code: E:missing bitmap icon_att_fota_installing (code -1) E:missing bitmap icon_att_fota_updating (code -1) E:missing bitmap icon_att_fota_complete (code -1) E:missing bitmap icon_att_fota_error (code -1) E:missing bitmap icon_tmo_fota_complete (code -1) E:missing bitmap icon_tmo_fota_error (code -1) #Manual MODE # -- Applying Multi-CSC... Applied the CSC -code : PAK Successfully applied multi-CSC | |
05-09-2014, 00:02 | #11 (permalink) |
Member: 1918391 Status: Offline Thanks Meter: 73 | i find a new way for this problem. S7262XEUAMI6_OXEAMI4(split rom) and flashed cwm recovery 6.0 with odin 3.09 working now cwm. Last edited by Octopus box; 05-09-2014 at 06:37. |
The Following User Says Thank You to gencom For This Useful Post: |
