02-06-2016, 15:09 | #1 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 468656 Status: Offline Thanks Meter: 76 | Sam sung S6 G920T after unlock imei 3500000...! Code: Welcome to Octoplus/Octopus Box Samsung software version 2.1.9 ----------------------------------------------------------------------------------- To connect SM-G920T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G920T Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G920T Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM223 Port is busy Connecting to phone on COM224 Port is busy No diagnostic ports found! Connecting to phone on COM8 Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T Port is busy Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM223 Port is busy Connecting to phone on COM224 Port is busy No diagnostic ports found! Connecting to phone on COM8 Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T Searching for a phone. Please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Phone found. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Thu Jun 11 22:19:54 KST 2015 PDA version: G920TUVU2COF6 CSC version: G920TTMB2COF6 SW version: G920TUVU2COF6 Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T Selected file: C:\Documents and Settings\phuong\My Documents \Downloads\cert-sm-g920t_359362060124295_r58g31hj5qm.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920T Firmware compiled date: Thu Jun 11 22:19:54 KST 2015 PDA version: G920TUVU2COF6 CSC version: G920TTMB2COF6 SW version: G920TUVU2COF6 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920T-Unknown06-02-2016_20-51-25-.asec file Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Exploit has been executed successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920T Firmware compiled date: Thu Jun 11 22:19:54 KST 2015 PDA version: G920TUVU2COF6 CSC version: G920TTMB2COF6 SW version: G920TUVU2COF6 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920T-Unknown06-02-2016_20-52-59-.asec file Unlocking phone... ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T Selected file: C:\Documents and Settings\phuong\My Documents \Downloads\cert-sm-g920t_359362060124295_r58g31hj5qm.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920T Firmware compiled date: Thu Jun 11 22:19:54 KST 2015 PDA version: G920TUVU2COF6 CSC version: G920TTMB2COF6 SW version: G920TUVU2COF6 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920T-Unknown06-02-2016_20-54-11-.asec file Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Exploit has been executed successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920T Firmware compiled date: Thu Jun 11 22:19:54 KST 2015 PDA version: G920TUVU2COF6 CSC version: G920TTMB2COF6 SW version: G920TUVU2COF6 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920T-Unknown06-02-2016_20-56-20-.asec file Wiping EFS... Phone will restart now. Please don't disconnect cable! EFS wipe successfully Searching for a phone. Please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920T Firmware compiled date: Thu Jun 11 22:19:54 KST 2015 PDA version: G920TUVU2COF6 CSC version: G920TTMB2COF6 SW version: G920TUVU2COF6 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Repairing security Security repair successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T Selected file: C:\Documents and Settings\phuong\My Documents \Downloads\cert-sm-g920t-357746060831994-r58g31myxyb.cert ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920T Firmware compiled date: Thu Jun 11 22:19:54 KST 2015 PDA version: G920TUVU2COF6 CSC version: G920TTMB2COF6 SW version: G920TUVU2COF6 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920T-Unknown06-02-2016_21-00-19-.asec file Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Exploit has been executed successfully Certificate has been written successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920T Firmware compiled date: Thu Jun 11 22:19:54 KST 2015 PDA version: G920TUVU2COF6 CSC version: G920TTMB2COF6 SW version: G920TUVU2COF6 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920T-Unknown06-02-2016_21-04-43-.asec file Deactivating MSL... Executing exploit... Exploit has been executed successfully MSL deactivate successfully Reading phone unlock codes. It can take some time, please wait... Can't find code! Work time: 0:02:18 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920T Firmware compiled date: Thu Jun 11 22:19:54 KST 2015 PDA version: G920TUVU2COF6 CSC version: G920TTMB2COF6 SW version: G920TUVU2COF6 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920T-Unknown06-02-2016_21-08-28-.asec file Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920T Firmware compiled date: Thu Jun 11 22:19:54 KST 2015 PDA version: G920TUVU2COF6 CSC version: G920TTMB2COF6 SW version: G920TUVU2COF6 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Writing security backup, please wait... Phone will restart now. Please don't disconnect cable! Security write successfully. Last edited by Octopus box; 02-06-2016 at 15:32. |
The Following User Says Thank You to duyphuong3000 For This Useful Post: |
02-06-2016, 15:19 | #2 (permalink) |
Member: 468656 Status: Offline Thanks Meter: 76 | Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920T Firmware compiled date: Thu Jun 11 22:19:54 KST 2015 PDA version: G920TUVU2COF6 CSC version: G920TTMB2COF6 SW version: G920TUVU2COF6 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G920T-Unknown06-02-2016_21-22-09-.asec file Unlocking phone... Deactivating MSL... Executing exploit... Exploit has been executed successfully Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. After unlock imei is still but network lock... team plz help! |
02-06-2016, 15:26 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please do the next: 1. Write first Security backup back into the phone. 2. Make Factroy Reset and reflash the phone with "G920TUVS3DOJC_G920TTMB3DOJC_TMB_Android_5.1.1 " firmware from the Support Area. 3. Root the phone with CF Auto Root. 4. Repeat "Unlock" operation. If phone has problem with Network after "Unlock" operation - try to write a Cert file, then try to find and select Network manually. Last edited by Octopus box; 02-06-2016 at 15:31. |
02-06-2016, 15:44 | #4 (permalink) | |
Member: 468656 Status: Offline Thanks Meter: 76 | Quote:
after unlock i was tested write cert again but my phone still lock sir. | |
02-06-2016, 16:03 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Use the very first Security backup of the phone that You have, and proceed with steps 2-4. Post here result and full Software log of performed operations. |
02-06-2016, 16:30 | #6 (permalink) | |
Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM8 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM8 Searching for a phone. Please wait... ADB server killed. Phone found. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM223 Selected model: SM-G920T Port is busy Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM8 Searching for a phone. Please wait... ADB server killed. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Mon Nov 30 10:58:17 KST 2015 PDA version: G920TUVS3DOJC CSC version: G920TTMB3DOJC SW version: G920TUVS3DOJC Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-G920T Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-G920T ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920T Firmware compiled date: Mon Nov 30 10:58:17 KST 2015 PDA version: G920TUVS3DOJC CSC version: G920TTMB3DOJC SW version: G920TUVS3DOJC Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920T-Unknown06-02-2016_22-31-28-.asec file Unlocking phone... Deactivating MSL... Executing exploit... Executing exploit failed Phone unlocking failed | |
02-06-2016, 16:39 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please close all third party Software and try to perfrom the operation again. Try to process the phone on another, clean (with only necessary drivers) PC. |
02-06-2016, 17:02 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please upload first Security backup of the phone (which You have), *.log and *.logx files of performed operations to any file-sharing service and post here download link. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
02-06-2016, 17:16 | #10 (permalink) |
Member: 468656 Status: Offline Thanks Meter: 76 | Security-SM-G920T-Unknown06-02-2016_18-44-00- - Download - 4shared *.log and *.logx files: log - Download - 4shared |
02-08-2016, 10:24 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | What exactly is not ok? Please write first Security backup back into the phone and repeat "Unlock" operation. If execution of exploit fails with 2.1.9 version of the Software - upload *.log and *.logx files of performed operations to any file-sharing service and post here download link. |
