03-18-2018, 09:18 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 608370 Status: Offline Thanks Meter: 89 | Samsung S8 SM-G950F Reset FRP question [Solved] any solution.... Please put the phone into Download Mode and connect USB cable. To put SM-G950F into Download Mode, You have to perform the following steps: 1. Power off the phone. 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.6.6 Software version. Selected firmware file: COMBINATION_FA70_G950FXXU1AQD1 _CL11075178_QB13087094_REV00_user_mid_noship.oct Please put the phone into Download Mode and connect USB cable. To put SM-G950F into Download Mode, You have to perform the following steps: 1. Power off the phone. 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing UP_PARAM section... UP_PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing NAD_FW section... NAD_FW section has been written successfully. Writing NAD_REFER section... NAD_REFER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing USERDATA section... USERDATA section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CP_DEBUG section... CP_DEBUG section has been written successfully. Firmware writing successfully completed. Performed by 2.6.6 Software version. ............................. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G950F Operation: Reset FRP - ADB Searching for a phone (waiting for ADB device)... Please, press "OK" button on the phone to allow USB debugging. Reading info... Detected phone model: SM-G950F Firmware compiled date: Sat Apr 1 15:00:15 KST 2017 PDA version: FA70_G950FXXU1AQD1 CSC version: unknown SW version: G950FXXU1AQC8 Phone SN: RF8J51A9P6E Android version: 7.0 (NRD90M) Sales code: unknown Country: unknown HW platform: exynos5 HW Chip: exynos8895 HW Modem: SHANNON355 Security patch level: 2017-02-01 SIM 1 status: ready Codename: dreamltexx Resetting FRP lock.. FRP lock is successfully reseted! Goto "Menu->Settings->Backup and reset" and make "Factory data reset" Performed by 2.6.6 Software version. Last edited by Octopus box; 03-22-2018 at 06:57. |
03-18-2018, 14:06 | #2 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | you are in menu now or stuck on configuration settings !!! |
The Following User Says Thank You to lerner_ For This Useful Post: |
03-18-2018, 16:37 | #3 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. You shouldn't write the full combination firmware before to perform "Reset FRP" operation, You need to write only boot image from combination firmware, please always attentively read Software manual ("Help" button in Software), before to perform any operation: Quote:
The Following 5 Users Say Thank You to Octopus box For This Useful Post: |
03-22-2018, 05:33 | #4 (permalink) | |
Member: 608370 Status: Offline Thanks Meter: 89 | Quote:
The Following User Says Thank You to prime_master786 For This Useful Post: |
07-25-2018, 17:25 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. No need to create, just select Combination firmware, put the device into Download (Emergency) Mode, press "Write Firmware" button, select "BOOT" image partition in dialog window, which appeared and write it. |
