07-30-2015, 14:27 | #1 (permalink) |
Freak Poster Join Date: Aug 2012 Location: Armenia Yerevan
Member: 1801587 Status: Offline Thanks Meter: 230 | Samsung A500FU no unlock android 5.0.2 [Solved] Welcome to Octoplus/Octopus Box Samsung software version 2.0.2 ----------------------------------------------------------------------------------- To connect SM-A500FU phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM114 Selected model: SM-A500FU Reading info... Mode: Normal Firmware compiled date: May 04 2015 Firmware compiled time: 07:00:00 Firmware released date: May 21 2015 Firmware released time: 16:09:24 SW Version: MPSS.DPM.2.0.c5-00075-M8936FAAAANUZM-1 Detected phone model: SM-A500FU Firmware compiled date: Thu May 21 16:53:55 KST 2015 PDA version: A500FUXXU1BOE6 CSC version: A500FUXEF1BOE1 SW version: A500FUXXU1BOE6 Phone IMEI: Unknown Phone SN: RF8G40X16GY Android version: 5.0.2 (LRX22G) Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone unlocking failed "*.log" and "*.logx" Last edited by Octopus box; 07-31-2015 at 12:50. |
07-30-2015, 14:40 | #3 (permalink) |
Member: 1801587 Status: Offline Thanks Meter: 230 | Platform: Samsung Android Selected port: COM114 Selected model: SM-A500F Reading info... Mode: Normal Firmware compiled date: May 04 2015 Firmware compiled time: 07:00:00 Firmware released date: May 21 2015 Firmware released time: 16:09:24 SW Version: MPSS.DPM.2.0.c5-00075-M8936FAAAANUZM-1 Detected phone model: SM-A500FU Firmware compiled date: Thu May 21 16:53:55 KST 2015 PDA version: A500FUXXU1BOE6 CSC version: A500FUXEF1BOE1 SW version: A500FUXXU1BOE6 Phone IMEI: Unknown Phone SN: RF8G40X16GY Android version: 5.0.2 (LRX22G) Checking Root: Phone is Rooted. Reading security backup, please wait... Unlocking phone... Phone unlocking failed |
07-30-2015, 14:50 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please upload *.log and *.logx files of "Unlock" operation, performed for rooted phone and post here download link. We will check, where might be the problem. |
07-30-2015, 14:59 | #5 (permalink) | |
Member: 1801587 Status: Offline Thanks Meter: 230 | Quote:
"*.log" and "*.logx" | |
07-30-2015, 16:31 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please check your PM, we have sent You test Software version. Try to perform "Unlock" operation with test Software and post the result. |
07-31-2015, 12:31 | #7 (permalink) | |
----------------------------------------------------------------------------------- To connect GT-I9506 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-A500FU phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM114 Selected model: SM-A500FU Mode: Normal Phone model: SM-A500FU Firmware compiled date: May 04 2015 Firmware compiled time: 07:00:00 Firmware released date: May 21 2015 Firmware released time: 16:09:24 Phone IMEI: 359469-06-152149-2 SW version: MPSS.DPM.2.0.c5-00075-M8936FAAAANUZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM114 Selected model: SM-A500FU Detected phone model: SM-A500FU Firmware compiled date: Thu May 21 16:53:55 KST 2015 PDA version: A500FUXXU1BOE6 CSC version: A500FUXEF1BOE1 SW version: A500FUXXU1BOE6 Phone IMEI: Unknown Phone SN: RF8G40X16GY Android version: 5.0.2 (LRX22G) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-A500FU-31-07-2015_15-25-02 file Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Unlock done 100% Thanks | |
The Following User Says Thank You to usta arman For This Useful Post: |
08-01-2015, 12:37 | #9 (permalink) |
Member: 1801587 Status: Offline Thanks Meter: 230 | I did so, set TWRP Recovery 2.8.7.0 and out flashed BETA-SuperSU-v2.49 Recovery 2.8.7.0 BETA-SuperSU-v2.49 |
08-13-2015, 15:30 | #10 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Here Age: 47
Member: 175183 Status: Offline Sonork: 0 Thanks Meter: 120 | Quote:
Can you help me to root A500FU ? | |
08-19-2015, 18:25 | #11 (permalink) |
No Life Poster Join Date: Dec 2013 Location: algeria
Member: 2081857 Status: Offline Sonork: 1000.2 Thanks Meter: 38 | download the some firmware if you are runing lolip v5.0.2 then extract the boot.img and recovery.img from firmware then flash cf root a500fu for kitkat 4.4.4 with odine then from ply store download flashfy flash the boot .img and recovery.img with this application and reboot the phone all done yours [email protected] |
The Following User Says Thank You to bibi018 For This Useful Post: |
08-19-2015, 20:51 | #12 (permalink) |
Junior Member Join Date: Sep 2007
Member: 579808 Status: Offline Thanks Meter: 5 | Decoding octopus does not at present on the version 5.0.2, and I think that for the downgrade, so kill my phone. NOT downgrade. I get the body like mine, and one can not lift the phone Last edited by coroisergei; 08-19-2015 at 20:56. |
