10-17-2016, 14:45 | #1 (permalink) |
Freak Poster Join Date: May 2011 Location: surat Age: 33
Member: 1574749 Status: Offline Sonork: 100.1641579 Thanks Meter: 63 | samsung a500g cert file need [Solved] my phone v. 5.0.2 Last edited by Octopus box; 10-21-2016 at 13:36. |
10-17-2016, 15:24 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. All Cert files, which we have at the moment, are available in "Samsung/For unlock and repair/Certificates" folder of the Support Area (Cert files compatibility). To enter Support Area, press "Go to support" button on "Support & options" tab of the Software. You can find a step by step description of how to write a Cert file in phone Software manual (press "Help" button in Software). |
10-19-2016, 08:25 | #4 (permalink) |
Member: 1574749 Status: Offline Sonork: 100.1641579 Thanks Meter: 63 | Welcome to Octoplus/Octopus Box Samsung software version 2.3.8 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G531F Warning: Selected model (SM-G531F) differs from the detected one (SM- A500G)! If you want select (SM-A500G) as (SM-G531F) model, please check "manual select". Writing Certificate failed Performed by 2.3.8 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G531F Warning: Selected model (SM-G531F) differs from the detected one (SM- A500G)! If you want select (SM-A500G) as (SM-G531F) model, please check "manual select". Writing Certificate failed Performed by 2.3.8 Software version. ----------------------------------------------------------------------------------- To connect SM-A500G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. Platform: Samsung Android Selected port: COM1 Selected model: SM-A500G Selected file: C:\Users\m.saad\Desktop\New folder (3)\Cert-SM-A500F_ 356316062038146.cert Select Certificate2... Selected file: C:\Users\m.saad\Desktop\New folder (3)\Cert-SM-A500F_ 356317062038144.cert Detected phone model: SM-A500G Firmware compiled date: Tue Apr 19 14:59:39 KST 2016 PDA version: A500GXXU1BPD1 CSC version: A500GODD1BPC3 SW version: A500GXXU1BPC2 Phone SN: RZ8H604DLPT Android version: 5.0.2 (LRX22G) Sales code: INS Country: India HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Codename: a5ltedd Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Please Reset MSL first! Writing Certificate failed Performed by 2.3.8 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A500G Detected phone model: SM-A500G Firmware compiled date: Tue Apr 19 14:59:39 KST 2016 PDA version: A500GXXU1BPD1 CSC version: A500GODD1BPC3 SW version: A500GXXU1BPC2 Phone SN: RZ8H604DLPT Android version: 5.0.2 (LRX22G) Sales code: INS Country: India HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Codename: a5ltedd Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP \Security-SM-A500G-19-10-2016_12-49-55 file Reseting MSL... MSL reset successfully. Please, restart the phone to apply changes Performed by 2.3.8 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A500G Selected file: C:\Users\m.saad\Desktop\New folder (3)\Cert-SM-A500F_ 356316062038146.cert Select Certificate2... Selected file: C:\Users\m.saad\Desktop\New folder (3)\Cert-SM-A500F_ 356317062038144.cert Detected phone model: SM-A500G Firmware compiled date: Tue Apr 19 14:59:39 KST 2016 PDA version: A500GXXU1BPD1 CSC version: A500GODD1BPC3 SW version: A500GXXU1BPC2 Phone SN: RZ8H604DLPT Android version: 5.0.2 (LRX22G) Sales code: INS Country: India HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Codename: a5ltedd Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Please Reset MSL first! Writing Certificate failed Performed by 2.3.8 Software version. |
10-19-2016, 08:56 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to reflash the phone with older (by release date) firmware, then repeat "Write Cecrt" operation. |
10-21-2016, 12:48 | #6 (permalink) |
Member: 1574749 Status: Offline Sonork: 100.1641579 Thanks Meter: 63 | Welcome to Octoplus/Octopus Box Samsung software version 2.3.8 ----------------------------------------------------------------------------------- To connect SM-A500G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A500G Detected phone model: SM-A500G Firmware compiled date: Thu Feb 26 14:34:44 KST 2015 PDA version: A500GXXU1AOB2 CSC version: A500GODD1AOB2 SW version: A500GXXU1AOB2 Phone IMEI: 359932065812423 Phone SN: RZ8H604DLPT Android version: 4.4.4 (KTU84P) Sales code: INS Country: India HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Codename: a5ltedd Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-A500G-21-10-2016_17-09-06 file Reseting MSL... MSL reset successfully. Please, restart the phone to apply changes Performed by 2.3.8 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A500G Selected file: C:\Users\m.saad\Desktop\New folder (3)\octo\Cert-SM- A500F_356316062038146.cert Select Certificate2... Selected file: C:\Users\m.saad\Desktop\New folder (3)\octo\Cert-SM- A500F_356317062038144.cert Detected phone model: SM-A500G Firmware compiled date: Thu Feb 26 14:34:44 KST 2015 PDA version: A500GXXU1AOB2 CSC version: A500GODD1AOB2 SW version: A500GXXU1AOB2 Phone IMEI: 359932065812423 Phone SN: RZ8H604DLPT Android version: 4.4.4 (KTU84P) Sales code: INS Country: India HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Codename: a5ltedd Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.3.8 Software version. job done after flash riset msl after write cert thanx to octopus teem best suport |
The Following User Says Thank You to ANISH SAMAJ For This Useful Post: |
