04-27-2015, 11:35 | #1 (permalink) |
Freak Poster Join Date: Apr 2009
Member: 1010764 Status: Offline Thanks Meter: 11 | samsung a700fd after unlock pin code ask Selected port: COM173 Selected model: SM-A700FD Reading info... Mode: Normal Firmware compiled date: Dec 23 2014 Firmware compiled time: 05:00:00 Firmware released date: Jan 9 2015 Firmware released time: 16:49:57 SW Version: MPSS.DPM.2.0.c5-00030-M8936FAAAANUZM- 1.11349.1.11526.1.11611.1 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-A700FD Firmware compiled date: Thu Jan 15 23:02:50 KST 2015 PDA version: A700FDXXU1AOAB CSC version: A700FDOLB1AOA4 SW version: A700FDXXU1AOA1 Phone IMEI: 35863706xxxxxxxx Phone SN: RF8G412L2EZ Android version: 4.4.4 (KTU84P) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-A700FD-27-04-2015_16-03-26 file Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
04-27-2015, 13:55 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | If after "Unlock" operation phone remains locked - currently no solution for such devices. You can try to unlock the phone via "Write Cert" operation, if You have compatible Certificate file. |
04-27-2015, 14:00 | #5 (permalink) |
Member: 1010764 Status: Offline Thanks Meter: 11 | Welcome to Octoplus/Octopus Box Samsung software version 1.9.3 ----------------------------------------------------------------------------------- To connect SM-A700FD phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM173 Selected model: SM-A700FD Reading info... Mode: Normal Firmware compiled date: Dec 23 2014 Firmware compiled time: 05:00:00 Firmware released date: Feb 3 2015 Firmware released time: 17:03:17 SW Version: MPSS.DPM.2.0.c5-00030-M8936FAAAANUZM- 1.11349.1.11526.1.11611.1 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-A700FD Firmware compiled date: Wed Jan 14 20:26:15 KST 2015 PDA version: A700FDXXU1AOAA CSC version: A700FDODD1AOA4 SW version: A700FDDDU1AOB1 Phone IMEI: 3586370xxxxxxxx Phone SN: RF8G412L2EZ Android version: 4.4.4 (KTU84P) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-A700FD-27-04-2015_18-25-57 file Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) same problem after reflash and unlock . i need cert file .. |
04-27-2015, 14:17 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Currently we don't have Cert files for SM-A700FD. All cert files, which we have at the moment, are available in "Samsung/FOR UNLOCK AND REPAIR/Certificates" folder of the Support Area. |
09-17-2015, 10:42 | #7 (permalink) | |
Freak Poster Join Date: Mar 2009 Location: 75.BAITUN NOOR SHOPPING CENTER
Member: 987131 Status: Offline Sonork: 100.1614852 Thanks Meter: 25 | A700FD No File FOR UNLOCK AND REPAIR/Certificates Quote:
Sir Need Samsung a700 fd Certificates File Place Help | |
09-17-2015, 11:04 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Unfortunately we don't have Cert files for SM-A700FD at the moment. As soon as manage to find Cert files for this model - they will be available in the Support Area. |
