04-20-2014, 02:49 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | Samsung E2202 after flash with Octopus dead and doesnt connect with PC now [Solved] Recived E2202 for Language , i flashed with files from Octopus support , now phone is fully deid and even cant detect to PC to reflash with another box. Last edited by Octopus box; 06-04-2014 at 12:00. |
04-20-2014, 07:16 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please post here full Software log with Write Firmware operation. Do the next: 1. Install the latest Software version (Software). 2. Fully charge phone's battery by using external charger. 3. Try to write firmware again. |
05-31-2014, 11:48 | #7 (permalink) |
Freak Poster Join Date: May 2014 Location: Turkey/İzmir
Member: 2187028 Status: Offline Thanks Meter: 21 | REPAİR--------------- Platform: Samsung Swift Selected model: GT-E1205T Selected port: COM3 Baud rate: 460800 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Searching patch area, please wait... ---------------------------------------------------------------------------- FULL FLASH---------------- Writing Full Flash Platform: Samsung Swift Selected model: GT-E1205T Selected port: COM3 Baud rate: 460800 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Writing Full Flash Erasing block... Block erase successfully. Writing Full Flash... Writing Full Flash Failed |
05-31-2014, 11:58 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | What Software version do You use exactly? Always post full Software log. |
05-31-2014, 14:51 | #10 (permalink) |
Member: 2187028 Status: Offline Thanks Meter: 21 | Software : Full_Flash-GT-E1205T-23-12-2013_19-12-16- ------------------------------------------------------------------------------------------------------------------------- Program Files\Octoplus\Octoplus_Samsung\LOG\27-05-2014_13-25-08.log" created (27.05.2014 13:25:10). ERROR : 27.05.2014 13:25:10 > Access violation at address 008F42F8 in module 'OctoplusSamsung.exe'. Read of address 00000004 INFO : 27.05.2014 13:25:11 > Set up system language Turkish (file: Turkish.ini) INFO : 27.05.2014 13:25:11 > Welcome to Octoplus/Octopus Box Samsung software version 1.5.7 INFO : 27.05.2014 13:25:19 > ----------------------------------------------------------------------------------- INFO : 27.05.2014 13:25:19 > Writing Full Flash INFO : 27.05.2014 13:25:20 > Platform: Samsung Swift INFO : 27.05.2014 13:25:20 > Selected model: GT-E1205T INFO : 27.05.2014 13:25:20 > Selected port: COM3 INFO : 27.05.2014 13:25:20 > Baud rate: 115200 WARN : 27.05.2014 13:25:20 > Please, connect phone to UART cable, insert battery and press power button for 3 seconds. INFO : 27.05.2014 13:25:20 > Phone found. INFO : 27.05.2014 13:25:20 > Sending preloader... INFO : 27.05.2014 13:25:22 > Preloader send successfully INFO : 27.05.2014 13:25:23 > Sending mainloader... INFO : 27.05.2014 13:25:29 > Mainloader send successfully INFO : 27.05.2014 13:25:29 > Writing Full Flash INFO : 27.05.2014 13:25:29 > Erasing block... INFO : 27.05.2014 13:26:02 > Block erase successfully. INFO : 27.05.2014 13:26:02 > Writing Full Flash... ERROR : 27.05.2014 13:26:04 > Writing Full Flash Failed |
05-31-2014, 15:41 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please upload *.log and *.logx files of the operation and post download linke here (these files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder). We will research the files to find out what causes this problem. |
06-03-2014, 10:49 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | We have prepared and sent test Software version to your PM. Try to write Full flash by using this test Software and post the result. Last edited by Octopus box; 06-03-2014 at 14:54. |
06-04-2014, 11:57 | #13 (permalink) |
Member: 2187028 Status: Offline Thanks Meter: 21 | Hello Octopus Team. GT-E1205TJALL1_XFMLK1.oct GT-E1205TJBLL1_XFVLK1.oct GT-E1205TJXMG1_OJXMG1.oct --------------------------------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-E1205T Selected port: COM3 Baud rate: 921600 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Reading flash memory parameters.. Setting baudrate.. Sending mainloader... Mainloader send successfully Writing firmware... Writing CLA section... Erasing block... Block erase successfully. Writing block... CLA section has been written successfully. Writing LPD section... LPD section has been written successfully. Formating TFS section Section TFS format successfully Writing TFS section... Writing Firmware Failed ----------------------------------------------------------------------------------- GT-E1205T-16-04-2014_15-01-58-.ful Writing Full Flash Platform: Samsung Swift Selected model: GT-E1205T Selected port: COM3 Baud rate: 921600 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Reading flash memory parameters.. Setting baudrate.. Sending mainloader... Mainloader send successfully Writing Full Flash Erasing block... Block erase successfully. Writing Full Flash... Full Flash write successfully -------------------------------------------------------------------------------------------------- İM** REPAİR OK THANK YOU OCTOPUS TEAM.. |
