11-24-2016, 08:29 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: pakistan Age: 34
Member: 294245 Status: Offline Sonork: 100.1602405 Thanks Meter: 115 | Samsung E2220 dead ----------------------------------------------------------------------------------- To connect SGH-I997 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090# or *#0808#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. Selected firmware file: E2220CEKI1_OCEKH3.oct ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-E2220 Selected port: USB Please, press "4" and "5" connect phone to USB without battery Connecting... Phone found. Chipset version : 0A SCROM version : 34 Sending loaders... Preloader send successfully Conecting to pipes... Successfully conecte to pipes. Writing firmware... Writing partition LCDACT ... Erasing block... Block erase successfully. Writing block... Partition LCDACT write successfully. Writing partition MAIN ... Erasing block... Writing Firmware Failed Performed by 2.4.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-E2220 Selected port: USB Please, press "4" and "5" connect phone to USB without battery Connecting... Phone found. Chipset version : 0A SCROM version : 34 Sending loaders... Preloader send successfully Conecting to pipes... Successfully conecte to pipes. Writing firmware... Writing partition LCDACT ... Erasing block... Block erase successfully. Writing block... Partition LCDACT write successfully. Writing partition MAIN ... Erasing block... Writing Firmware Failed Performed by 2.4.0 Software version. Stoped This stage change two files but same error full flash file not show on support site |
11-24-2016, 09:20 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. What was initial state of the phone? Why did You decide to reflash it? Try to write different firmwares from the Support Area one by one. |
11-24-2016, 13:35 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to write different firmwares from the Support Area one by one. |
11-28-2016, 09:18 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | If problem remains the same with different firmwares - try to reflash the phone with original firmware and flashing tool. |
