08-09-2015, 21:43 | #1 (permalink) |
Freak Poster Join Date: Aug 2013 Location: 408 ikwerre road rumuokwuta
Member: 1994486 Status: Offline Thanks Meter: 3 | Samsung G313HN exclamation mark after rooting |
08-10-2015, 09:12 | #4 (permalink) |
Member: 1994486 Status: Offline Thanks Meter: 3 | here is the screen shot To connect SM-G313HN phone you have to perform the following steps: INFO : 8/3/2015 4:03:45 AM > 1. Disconnect USB cable from phone. INFO : 8/3/2015 4:03:45 AM > 2. Go to Menu->Settings->More->About Device. INFO : 8/3/2015 4:03:45 AM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 8/3/2015 4:03:45 AM > 4. Go to Menu->Settings->More->Developer options. INFO : 8/3/2015 4:03:45 AM > 5. Turn on "USB Debugging" option. INFO : 8/3/2015 4:03:57 AM > Selected firmware file: G313HNDDU0ANH2_ROOT.oct WARN : 8/3/2015 4:03:59 AM > Please put the phone into Download Mode and connect USB cable. WARN : 8/3/2015 4:03:59 AM > To put SM-G313HN into Download Mode, You have to perform the following steps: WARN : 8/3/2015 4:03:59 AM > 1. Reconnect the battery. WARN : 8/3/2015 4:03:59 AM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 8/3/2015 4:03:59 AM > 3. When phone turns on, press "Volume+" key. INFO : 8/3/2015 4:03:59 AM > Found phone on INFO : 8/3/2015 4:03:59 AM > Firmware write started. INFO : 8/3/2015 4:03:59 AM > Writing KERNEL section... INFO : 8/3/2015 4:04:03 AM > KERNEL section has been written successfully. INFO : 8/3/2015 4:04:03 AM > Firmware writing successfully completed. |
08-10-2015, 09:24 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to make Factory Reset and Wipe cache partition from Recovery Mode. Try to reflash the phone with "g313hnxxu0anh3_g313hnoxx0anh2_phe_android_4.4 .2" firmware from the Support Area. |
08-11-2015, 16:39 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have uploaded "g313hnxxu0anl1_g313hnoxx0anh1_xeh_android_4.4 .2" firmware into the Support Area. Try to reflash the phone with this firmware and check whether phone powers on correctly, or enters Recovery Mode. |
