12-19-2014, 18:22 | #1 (permalink) |
Freak Poster Join Date: Sep 2010
Member: 1390215 Status: Offline Thanks Meter: 11 | Samsung G3815 imei lost [Solved] Restart phone and the imei is lost. Make a wipe and root. Activate usb debug. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. In this steep dont show nothing in the screen only ServiceMode menu but no options. Soft dont detect phone and cant repair imei. Code: Bienvenido en Octoplus/Octopus Box Samsung software versión 1.7.7 ----------------------------------------------------------------------------------- To connect SM-G3815 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ---------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM325 Modelo seleccionado: SM-G3815 Operación cancelada Writing EFS was canceled. Seleccione el archivo de firmware: G3815XXUBMK5_G3815VFGBMK5_Germany(Vodafone)_Android_4.2.2.oct Please put the phone into Download Mode and connect USB cable. To put SM-G3815 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Escribiendo la sección TZ... L a sección TZ ha sido escrita con éxito Escribiendo la sección BOOT... L a sección BOOT ha sido escrita con éxito Escribiendo la sección RECOVERY... L a sección RECOVERY ha sido escrita con éxito Escribiendo la sección SYSTEM... L a sección SYSTEM ha sido escrita con éxito Escribiendo la sección MODEM... L a sección MODEM ha sido escrita con éxito Escribiendo la sección CACHE... L a sección CACHE ha sido escrita con éxito Escribiendo la sección HIDDEN... L a sección HIDDEN ha sido escrita con éxito La escritura del firmware ha sido completada con éxito - Plataforma: Samsung Android Puerto seleccionado: COM326 Modelo seleccionado: SM-G3815 Modo: Normal Modelo del teléfono: SM-G3815 Fecha de creación del firmware: Tiempo de compilación del firmware: Fecha de salida del firmware: -ù~ Tiempo de salida del firmware: IMEI incorrecto Versión del SW: ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM326 Modelo seleccionado: SM-G3815 Modo: Normal Modelo del teléfono: SM-G3815 Fecha de creación del firmware: Tiempo de compilación del firmware: Fecha de salida del firmware: -ù~ Tiempo de salida del firmware: Versión del SW: ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM326 Modelo seleccionado: SM-G3815 Please select service IMEI for this phone model Write IMEI failed ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM325 Modelo seleccionado: SM-G3815 Please select service IMEI for this phone model Write IMEI failed ----------------------------------------------------------------------------------- |
12-19-2014, 18:29 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | What was the firmware version exactly in the phone before You have written firmware? Post here full Software log with phone's info, that was in the phone before. You should write the same or higher firmware version. We will upload new firmwares for this device for You into the Support Area in several hours. Also read out phone's info via ADB (turn on USB Debugging Mode in the phone and press "Read info" button at "Android / EFS manager" tab in the Software) and post here full Software log with this info. |
12-19-2014, 19:20 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have uploaded new firmwares for SM-G3815 into the Support Area. |
