01-31-2015, 12:31 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Lahore
Member: 392149 Status: Offline Thanks Meter: 199 | Samsung G530H cant write cert [Solved] Platform: Samsung Android Selected port: COM776 Selected model: SM-G530H Reading info, please wait... Detected phone model: SM-G530H Firmware compiled date: Tue Sep 23 10:51:50 KST 2014 PDA version: G530HXXU1ANIJ CSC version: G530HOJV1ANJ1 SW version: G530HXXU1ANIJ Phone IMEI: Unknown Android version: 4.4.4 (KTU84P) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM776 Selected model: SM-G530H Selected file: C:\Documents and Settings\MAHAD\My Documents \Downloads\Cert_SM-G530H_355677060467699.cert Select Certificate2... Last edited by Octopus box; 02-01-2015 at 09:51. |
01-31-2015, 12:38 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Do the next: 1. Install the latest Software version (Software). 2. Root the phone. 3. Make Wipe Security. 4. Block highlighted pin with a tape. 5. Write IMEI Certificate. Also, look here: http://forum.gsmhosting.com/vbb/f684...55/index2.html, http://forum.gsmhosting.com/vbb/f684...fully-1909286/, http://forum.gsmhosting.com/vbb/f684...i-log-1909429/, http://forum.gsmhosting.com/vbb/f684...-done-1909357/, http://forum.gsmhosting.com/vbb/f684...-done-1909331/. |
01-31-2015, 12:43 | #3 (permalink) | |
Member: 392149 Status: Offline Thanks Meter: 199 | Quote:
Am also do these steps but same | |
01-31-2015, 12:48 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Look here: http://forum.gsmhosting.com/vbb/f684...100-a-1909650/, maybe You do something wrong or use the same IMEI Certificate file twice at the same time. Make copy of the Certificate file and then select it as second Certificate And post here full Software log, not reduced. |
01-31-2015, 13:13 | #5 (permalink) | |
INFO : 1/31/2015 5:03:40 PM > Platform: Samsung Android INFO : 1/31/2015 5:03:40 PM > Selected port: COM9 INFO : 1/31/2015 5:03:40 PM > Selected model: SM-G530H INFO : 1/31/2015 5:03:46 PM > Selected file: C:\Documents and Settings\MAHAD\My Documents\Cert_SM-G530H_355677060467699.cert INFO : 1/31/2015 5:03:46 PM > Select Certificate2... INFO : 1/31/2015 5:03:51 PM > Selected file: C:\Documents and Settings\MAHAD\My Documents\Downloads\Cert_SM-G530H_355677060467699.cert WARN : 1/31/2015 5:03:53 PM > Powered on perform the following steps: WARN : 1/31/2015 5:03:53 PM > 1. Connect phone via UART cable to the Box. WARN : 1/31/2015 5:03:53 PM > 2. Note: phone screen must be active INFO : 1/31/2015 5:03:53 PM > Connecting to phone, please wait... INFO : 1/31/2015 5:03:58 PM > Found phone on COM9 INFO : 1/31/2015 5:03:58 PM > Phone connected successfully INFO : 1/31/2015 5:03:58 PM > Checking Certificate file... INFO : 1/31/2015 5:03:58 PM > Certificate file successfully checked INFO : 1/31/2015 5:03:58 PM > Writing new phone IMEI... INFO : 1/31/2015 5:04:10 PM > Checking certificate compatibility... INFO : 1/31/2015 5:04:10 PM > Certificate is compatible INFO : 1/31/2015 5:04:10 PM > Writing Certificate... INFO : 1/31/2015 5:04:17 PM > Checking Certificate file... INFO : 1/31/2015 5:04:17 PM > Certificate file successfully checked INFO : 1/31/2015 5:04:17 PM > Writing new phone IMEI... INFO : 1/31/2015 5:04:17 PM > Checking certificate compatibility... INFO : 1/31/2015 5:04:17 PM > Certificate is compatible INFO : 1/31/2015 5:04:17 PM > Writing Certificate... INFO : 1/31/2015 5:04:24 PM > Certificate has been written successfully INFO : 1/31/2015 5:04:24 PM > Please, restart the phone to apply changes | |
01-31-2015, 20:16 | #6 (permalink) |
Insane Poster Join Date: Aug 2008
Member: 839068 Status: Offline Thanks Meter: 8 | To connect SM-G530H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM441 Selected model: SM-G530H Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G530H Firmware compiled date: Tue Sep 23 10:51:50 KST 2014 PDA version: G530HXXU1ANIJ CSC version: G530HODD1ANI5 SW version: G530HXXU1ANIJ Phone IMEI: 000000015856784 Phone SN: RF1FB11TRGH Android version: 4.4.4 (KTU84P) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM441 Selected model: SM-G530H Detected phone model: SM-G530H Firmware compiled date: Tue Sep 23 10:51:50 KST 2014 PDA version: G530HXXU1ANIJ CSC version: G530HODD1ANI5 SW version: G530HXXU1ANIJ Phone IMEI: 000000015856784 Phone SN: RF1FB11TRGH Android version: 4.4.4 (KTU84P) Reading info... Mode: Normal Firmware compiled date: Sep 20 2014 Firmware compiled time: 08:00:00 Firmware released date: Sep 23 2014 Firmware released time: 09:55:53 SW Version: MPSS.DPM.1.0.c7.1-00034-M8916EAAAANVZM-1.5920.1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G530H-000000015856784-30-01-2015_19-12- 34-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G530H-000000015856784-30-01-2015_19-16- 08-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Sep 20 2014 Firmware compiled time: 08:00:00 Firmware released date: Sep 23 2014 Firmware released time: 09:55:53 SW Version: MPSS.DPM.1.0.c7.1-00034-M8916EAAAANVZM-1.5920.1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-G530H Selected file: C:\Users\Sherry\Desktop\g530h\cert_sm-g530h_ 355677060467699.cert Select Certificate2... Selected file: C:\Users\Sherry\Desktop\g530h\2 cert_sm-g530h_ 355677060467699.cert Powered on perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM13 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes |
