02-06-2015, 14:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Mobile phone world
Member: 90701 Status: Offline Thanks Meter: 134 | Samsung G530h Cert file writing failed [Solved] Logs: Platform: Samsung Android Selected port: COM97 Selected model: SM-G530H Selected file: D:\Mobile\Octopus\Samsung\Cert\530h cert 100 work \Cert_SM-G530H_ 1 .cert Select Certificate2... Selected file: D:\Mobile\Octopus\Samsung\Cert\530h cert 100 work \Cert_SM-G530H_ 2.cert Powered on perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found more then one box connected to COM10 Found phone on COM10 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Writing Certificate failed Last edited by Octopus box; 02-07-2015 at 13:28. |
The Following User Says Thank You to Unicom For This Useful Post: |
02-06-2015, 14:46 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Do the next: 1. Install the latest Software version (Software). 2. Root the phone. 3. Make Wipe Security. 4. Block highlighted pin with a tape. 5. Write IMEI Certificates (write the same Certificate "Cert_SM-G530H_355677060467699.cert" for both IMEIs from the Support Area). 6. Write this QCN: https://mega.co.nz/#!j0IQ2LLY!IKbj3W...cg8UgfGXpHBpAU. Also, look here: http://forum.gsmhosting.com/vbb/f684...olved-1910729/, http://forum.gsmhosting.com/vbb/f684...100-a-1909650/, http://forum.gsmhosting.com/vbb/f684...55/index2.html, http://forum.gsmhosting.com/vbb/f684...fully-1909286/, http://forum.gsmhosting.com/vbb/f684...i-log-1909429/, http://forum.gsmhosting.com/vbb/f684...-done-1909357/, http://forum.gsmhosting.com/vbb/f684...-done-1909331/. |
02-06-2015, 16:35 | #3 (permalink) |
No Life Poster Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | INFO : 2/6/2015 1:52:30 PM > Platform: Samsung Android INFO : 2/6/2015 1:52:30 PM > Selected port: COM1 INFO : 2/6/2015 1:52:30 PM > Selected model: SM-G530H INFO : 2/6/2015 1:52:33 PM > Selected file: C:\Users\user\Desktop\Samsung G530H 1000% Network Working CERT & NV tested\Samsung G530H 1000% Network Working CERT & NV tested\Cert_SM-G530H_ 1 .cert INFO : 2/6/2015 1:52:33 PM > Select Certificate2... INFO : 2/6/2015 1:52:35 PM > Selected file: C:\Users\user\Desktop\Samsung G530H 1000% Network Working CERT & NV tested\Samsung G530H 1000% Network Working CERT & NV tested\Cert_SM-G530H_ 2.cert WARN : 2/6/2015 1:52:44 PM > Powered on perform the following steps: WARN : 2/6/2015 1:52:44 PM > 1. Connect phone via UART cable to the Box. WARN : 2/6/2015 1:52:44 PM > 2. Note: phone screen must be active INFO : 2/6/2015 1:52:44 PM > Connecting to phone, please wait... ERROR : 2/6/2015 1:53:51 PM > Writing Certificate failed INFO : 2/6/2015 1:54:01 PM > ----------------------------------------------------------------------------------- INFO : 2/6/2015 1:54:01 PM > Platform: Samsung Android INFO : 2/6/2015 1:54:01 PM > Selected port: COM1 INFO : 2/6/2015 1:54:01 PM > Selected model: SM-G530H INFO : 2/6/2015 1:54:03 PM > Selected file: C:\Users\user\Desktop\Samsung G530H 1000% Network Working CERT & NV tested\Samsung G530H 1000% Network Working CERT & NV tested\Cert_SM-G530H_ 1 .cert INFO : 2/6/2015 1:54:03 PM > Select Certificate2... INFO : 2/6/2015 1:54:06 PM > Selected file: C:\Users\user\Desktop\Samsung G530H 1000% Network Working CERT & NV tested\Samsung G530H 1000% Network Working CERT & NV tested\Cert_SM-G530H_ 2.cert WARN : 2/6/2015 1:54:07 PM > Powered on perform the following steps: WARN : 2/6/2015 1:54:07 PM > 1. Connect phone via UART cable to the Box. WARN : 2/6/2015 1:54:07 PM > 2. Note: phone screen must be active INFO : 2/6/2015 1:54:07 PM > Connecting to phone, please wait... ERROR : 2/6/2015 1:54:29 PM > Writing Certificate failed INFO : 2/6/2015 1:57:18 PM > ----------------------------------------------------------------------------------- INFO : 2/6/2015 1:57:18 PM > Platform: Samsung Android INFO : 2/6/2015 1:57:18 PM > Selected port: COM1 INFO : 2/6/2015 1:57:18 PM > Selected model: SM-G530H INFO : 2/6/2015 1:57:20 PM > Selected file: C:\Users\user\Desktop\Samsung G530H 1000% Network Working CERT & NV tested\Samsung G530H 1000% Network Working CERT & NV tested\Cert_SM-G530H_ 1 .cert INFO : 2/6/2015 1:57:20 PM > Select Certificate2... INFO : 2/6/2015 1:57:22 PM > Selected file: C:\Users\user\Desktop\Samsung G530H 1000% Network Working CERT & NV tested\Samsung G530H 1000% Network Working CERT & NV tested\Cert_SM-G530H_ 2.cert WARN : 2/6/2015 2:05:13 PM > Powered on perform the following steps: WARN : 2/6/2015 2:05:13 PM > 1. Connect phone via UART cable to the Box. WARN : 2/6/2015 2:05:13 PM > 2. Note: phone screen must be active INFO : 2/6/2015 2:05:13 PM > Connecting to phone, please wait... WARN : 2/6/2015 2:05:16 PM > Application will be closed now. Please, wait until all operations are finished. ERROR : 2/6/2015 2:05:16 PM > Writing Certificate failed |
02-06-2015, 16:41 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Disconnect all other devices from PC, reboot the PC,close all running applications on the PC (antivirus, firewall, browsers and others), take out SIM and SD cards from the phone and perform all of the steps 1-6, mentioned above. Try to perform the same actions on another PC. |
02-06-2015, 16:53 | #5 (permalink) | |
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | Quote:
02-06-2015, 17:01 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Do exactly the next: 1. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 2. Take out SIM and SD cards from the device. 3. Run the Software. 4. Make Factory data reset and wipe cache partition. 5. Make Wipe Security again. 6. Write IMEI Certificates again. Make copy of this IMEI certificate file ("Cert_SM-G530H_355677060467699.cert") and use it for the second IMEI. 7. Close the Software. 8. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the links, we will research, where can be the problem with your device. |
02-07-2015, 00:19 | #7 (permalink) | |
----------------------------------------------------------------------------------- To connect SM-G530H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G530H Firmware compiled date: Tue Sep 23 10:51:50 KST 2014 PDA version: G530HXXU1ANIJ CSC version: G530HODD1ANI5 SW version: G530HXXU1ANIJ Phone IMEI: Unknown Phone SN: R51FC1N55KR Android version: 4.4.4 (KTU84P) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Detected phone model: SM-G530H Firmware compiled date: Tue Sep 23 10:51:50 KST 2014 PDA version: G530HXXU1ANIJ CSC version: G530HODD1ANI5 SW version: G530HXXU1ANIJ Phone IMEI: Unknown Phone SN: R51FC1N55KR Android version: 4.4.4 (KTU84P) Reading info... Mode: Normal Firmware compiled date: Sep 20 2014 Firmware compiled time: 08:00:00 Firmware released date: Sep 23 2014 Firmware released time: 09:55:53 SW Version: MPSS.DPM.1.0.c7.1-00034-M8916EAAAANVZM-1.5920.1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G530H-06-02-2015_23-49-41-.qcn file Checking Root: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Reading info, please wait... Detected phone model: SM-G530H Firmware compiled date: Tue Sep 23 10:51:50 KST 2014 PDA version: G530HXXU1ANIJ CSC version: G530HODD1ANI5 SW version: G530HXXU1ANIJ Phone IMEI: Unknown Phone SN: R51FC1N55KR Android version: 4.4.4 (KTU84P) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Detected phone model: SM-G530H Firmware compiled date: Tue Sep 23 10:51:50 KST 2014 PDA version: G530HXXU1ANIJ CSC version: G530HODD1ANI5 SW version: G530HXXU1ANIJ Phone IMEI: Unknown Phone SN: R51FC1N55KR Android version: 4.4.4 (KTU84P) Reading info... Mode: Normal Firmware compiled date: Sep 20 2014 Firmware compiled time: 08:00:00 Firmware released date: Sep 23 2014 Firmware released time: 09:55:53 SW Version: MPSS.DPM.1.0.c7.1-00034-M8916EAAAANVZM-1.5920.1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G530H-06-02-2015_23-58-13-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G530H-07-02-2015_00-02-19-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Sep 20 2014 Firmware compiled time: 08:00:00 Firmware released date: Sep 23 2014 Firmware released time: 09:55:53 SW Version: MPSS.DPM.1.0.c7.1-00034-M8916EAAAANVZM-1.5920.1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Selected file: C:\Users\user\Desktop\g530h final cert\Cert_SM-G530H_ 355677060467699.cert Select Certificate2... Selected file: C:\Users\user\Desktop\g530h final cert\Cert-SM-G530H_ 00000001585678_0000000000.cert Powered on perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Reading info, please wait... Detected phone model: SM-G530H Firmware compiled date: Tue Sep 23 10:51:50 KST 2014 PDA version: G530HXXU1ANIJ CSC version: G530HODD1ANI5 SW version: G530HXXU1ANIJ Phone IMEI: Unknown Phone SN: R51FC1N55KR Android version: 4.4.4 (KTU84P) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Selected file: C:\Users\user\Desktop\g530h final cert\Cert_SM-G530H_ 355677060467699.cert Select Certificate2... Selected file: C:\Users\user\Desktop\g530h final cert\Cert-SM-G530H_ 00000001585678_0000000000.cert Powered on perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Selected file: C:\Users\user\Desktop\g530h final cert\Cert_SM-G530H_ 355677060467699.cert Select Certificate2... Selected file: C:\Users\user\Desktop\g530h final cert\Cert-SM-G530H_ 00000001585678_0000000000.cert Powered on perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Selected file: C:\Users\user\Desktop\g530h final cert\Cert_SM-G530H_ 355677060467699.cert Select Certificate2... Selected file: C:\Users\user\Desktop\g530h final cert\Cert-SM-G530H_ 00000001585678_0000000000.cert Powered on perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Selected file: C:\Users\user\Desktop\g530h final cert\Cert_SM-G530H_ 355677060467699.cert Select Certificate2... Selected file: C:\Users\user\Desktop\g530h final cert\Cert-SM-G530H_ 00000001585678_0000000000.cert Powered on perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Selected file: C:\Users\user\Desktop\g530h final cert\Cert_SM-G530H_ 355677060467699.cert Select Certificate2... Selected file: C:\Users\user\Desktop\g530h final cert\Cert-SM-G530H_ 00000001585678_0000000000.cert Powered on perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed | |
02-07-2015, 09:14 | #8 (permalink) | |||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | 1. Where is links to "*.log" and "*.logx" files?: Quote:
3. Try to use another Samsung Micro UART C3300k/C3303k cable, maybe the problem is with your cable. 4. Try to use another Box as UART interface, maybe the problem is with Box COM port. 5. Read carefully, what I have written above: Quote:
02-07-2015, 13:16 | #9 (permalink) | |
----------------------------------------------------------------------------------- To connect SM-G530H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM285 Selected model: SM-G530H Reading info, please wait... Detected phone model: SM-G530H Firmware compiled date: Tue Sep 23 10:51:50 KST 2014 PDA version: G530HXXU1ANIJ CSC version: G530HODD1ANI5 SW version: G530HXXU1ANIJ Phone IMEI: Unknown Phone SN: R51FC1N55KR Android version: 4.4.4 (KTU84P) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM285 Selected model: SM-G530H Selected file: C:\Users\user\Desktop\Samsung G530H 1000% Network Working CERT & NV tested\Samsung G530H 1000% Network Working CERT & NV tested\Cert_SM-G530H_ 1 .cert Select Certificate2... Selected file: C:\Users\user\Desktop\Samsung G530H 1000% Network Working CERT & NV tested\Samsung G530H 1000% Network Working CERT & NV tested\Cert_SM-G530H_ 2.cert Powered on perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM45 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes thanks is done now | |
