08-25-2017, 20:14 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | SM-G950U MSL Unlock Error ----------------------------------------------------------------------- Connecting to server..OK Username: Authorization.. Login error: Wrong username! ----------------------------------------------------------------------- Selected interface: USB Searching for device. Please wait... Waiting for device... Found device on COM145 Reading info... Detected device model: SM-G950U HW Version: ATT PDA version: G950USQU1AQC9 CSC version: G950UOYN1AQC9 CP version: G950USQU1AQC9 Device SN: R38J402D5ZF Device IMEI: samusprime FRP/Reactivation: UNLOCK MSL code: 5405015B09145F09625E30491B5C014A Deactivating MSL... AKSEED error! Last edited by Octopus box; 08-26-2017 at 08:31. |
08-26-2017, 08:12 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please upload *.log and *.logx files of performed operations to any file-sharing service and post here download link. We will check what causes the problem. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
09-11-2017, 19:15 | #3 (permalink) | |
Member: 189984 Status: Offline Thanks Meter: 112 | Quote:
09-14-2017, 02:57 | #5 (permalink) | |
https://www.4shared.com/file/VKbDJ_q..._13-01-56.html | |
09-14-2017, 06:26 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hi. Quote:
09-14-2017, 06:50 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | No, unfortunately, You should have special UART type-C cable, this adapter will not work. The problem is that your phone doesn't answer to some Software CMDs via USB cable. You can try to re-flash the phone with another firmware, maybe with new firmware, operations will work via USB cable. Last edited by Octopus box; 09-14-2017 at 08:01. |
09-14-2017, 18:29 | #9 (permalink) |
Member: 189984 Status: Offline Thanks Meter: 112 | Hello, I tried with different firmwares without no luck . And what kind of the special UART type-C cable? There is any schematic to do it? Last edited by samusprime; 09-14-2017 at 18:37. |
