02-27-2016, 07:43 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india kerala,MALAPURAM EDAKKAR
Member: 1224654 Status: Offline Sonork: jaheer Thanks Meter: 61 | samsung g850y frp lock reset failed Welcome to Octoplus/Octopus Box Samsung software version 2.2.1 ----------------------------------------------------------------------------------- To connect SM-G850Y phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G850Y Reset Screen Lock cancelled! Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G850Y To put SM-G850Y into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..not supported Resetting EE lock..not supported Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.1 software version |
02-27-2016, 08:52 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. As You can see from your Software log, reset FRP is not supported for this phone's firmware. You can try to write another firmware and try to repeat the operation once again. Note, writing older firmware version or boot can damage your device. Last edited by Octopus box; 02-27-2016 at 12:25. |
