01-09-2017, 06:09 | #1 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2526473 Status: Offline Thanks Meter: 0 | Samsung SM-G920P no service [Answered] My phone is Samsung G920P My dosen't have Antenna and I download flash file 5.1.1 but it doesn't work on my phone is any way to resolve this problem? Last edited by Octopus box; 09-24-2018 at 12:04. |
01-09-2017, 10:31 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. After what actions with the phone problem with Network occurred? Please check whether GSM/(E)GPRS/WCDMA GCF is enabled in your phone: 1. Open hidden menu. There are two ways of doing it: 1) Run the following command via ADB: Code: adb shell su -c "am broadcast -a android.provider.Telephony.SECRET_CODE -d android_secret_code://IOTHIDDENMENU" 2) Perform the following actions: 1. Dial *#0011# and in the service menu do the following. 2. Click "Menu" then "Key input" then input Q then press "Ok". 3. Click "Menu" then "Back". 4. Click "Menu" then "Key input" then input 0000 then click "Ok". 2. After these steps Hidden menu should open. In Hidden menu, depending on available options, try to do the following: I.
II.
After these actions go to Settings -> Mobile Networks and Set Network Mode to Automatic, or GSM. |
01-09-2017, 12:37 | #3 (permalink) |
Insane Poster Join Date: Feb 2014 Location: Leesburg,FL
Member: 2138194 Status: Offline Thanks Meter: 2 | It's possible you may need to download 6.0.1 for the G920P Sent from my iPhone using Tapatalk Pro |
The Following User Says Thank You to justdewwit For This Useful Post: |
01-10-2017, 08:47 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | To open hidden menu You need to use one of the described above methods. |
09-24-2018, 11:18 | #6 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | just try this way 100% work 1. Dial ##72786# 2. Press Yes to reset the Provisioning Settings to default. 3. Reboot the Phone |
The Following 4 Users Say Thank You to Tanha0321 For This Useful Post: |
