05-24-2017, 14:05 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | samsung g925f unlock so i tried unlock without root it was ask to downgrade modem file so i did flash modem (get from support ) after write baseband unknow what i do next? here is log of work Code: Welcome to Octoplus/Octopus Box Samsung software version 2.5.3 ----------------------------------------------------------------------------------- To connect SM-G925F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: MODEM_G925FXXU4DPHF_Android_6.0.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G925F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing RADIO section... RADIO section has been written successfully. Firmware writing successfully completed. Performed by 2.5.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G925F Searching for a phone. Please wait... Phone was not found on the selected port! Phone unlocking failed Performed by 2.5.3 Software version. |
05-24-2017, 14:40 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. If phone's baseband became unknown after writing of modem - this modem is not compatible with current firmware of the phone. You should write initial modem back into the phone, or write a complete firmware. |
05-24-2017, 14:47 | #3 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 48
Member: 6524 Status: Offline Thanks Meter: 246 | Reflash phone with 7.0 or write .07 modem file Quote:
Reflash phone 7 fw or write 7fw modem then imei will back..need more help contact me via skype | |
05-24-2017, 16:08 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Unfortunately "Unlock" operation is not supported for SM-G925F on Android 7 firmware at the moment. To unlock the phone You can try to downgrade firmware version to Android 6.x (write complete firmware, not only modem). |
05-24-2017, 16:14 | #6 (permalink) | |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
if i check download mode reactivation on is it have 99% stop ishue? | |
