01-18-2016, 08:45 | #1 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1561570 Status: Offline Thanks Meter: 4 | samsung g925i need help.. imei is good 35812106068***... version 5.1.1 baseband version g925IDVU3DOJ6.. PLS help or any idea to solve this problem..i want to try software first before hardware or repair the board,,but i need any idea or solution pls help me,,tnx in advance.. |
01-18-2016, 12:46 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please check status of IMEI Certi in *#0011# menu. Also, check whether phone's IMEI is not in "black" list of Network provider. |
01-18-2016, 15:13 | #3 (permalink) | |
Member: 1561570 Status: Offline Thanks Meter: 4 | Quote:
here sir 2g-basic info REG STATUS:<NOT _REGISTER> MCC:420 MNC :03 RAT:GSM(2G),BAND:PGSM900 BCCH arfc:45,Rx Lvl:-68 TCH Rx Lvl:--Rx Q:-- NOM :256,Rac :255 Cellld :0x49592,Lac Timing Advance : 0 Tx_Pwr_Lvl: 0 Freq Hopping Status:<OFF> IMEI Status : OK | |
01-18-2016, 15:17 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please make Factory Reset and reflash the phone. Try to find and select Network manually, then try to make a call. Note: it might be needed to root the phone after writing of a firmware, if it won't turn on correctly. |
