03-11-2017, 19:07 | #16 (permalink) | |
Junior Member Join Date: Feb 2010 Location: Kyrgyzstan
Member: 1238481 Status: Offline Sonork: 239743 Thanks Meter: 1 | Quote:
https://yadi.sk/d/V8yT4E8C3FXczi | |
03-12-2017, 04:28 | #19 (permalink) | |
Link for photos ---- https://yadi.sk/d/V8yT4E8C3FXczi | |
03-12-2017, 06:34 | #20 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | brother see this link and download 6.0.1 and full flash phone https://samsung-firmware.org/model/SM-G930F/region/VDS/ |
03-12-2017, 11:42 | #21 (permalink) | |
03-12-2017, 15:46 | #23 (permalink) |
Member: 1238481 Status: Offline Sonork: 239743 Thanks Meter: 1 | yes. but dont help . please help me. https://yadi.sk/d/V8yT4E8C3FXczi Here there are all the photos of my device |
03-18-2017, 20:13 | #27 (permalink) | |
No Life Poster Join Date: Jun 2016 Location: every ware in your hart
Member: 2590583 Status: Offline Thanks Meter: 198 | Quote:
Sent from my SM-A300FU using Tapatalk | |
03-25-2017, 09:48 | #29 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Problem with reset of FRP lock can occur if phone has one of the latest firmwares. Samsung disabled ability to remove FRP lock in latest firmwares. There are few methods, of how to reset FPR on phones with latest firmwares: I. Try to write SBoot file of older firmware. Repeat "Reset FRP/Reactivation/EE" operation. II. Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check partitions except "boot.img"). Perform "Reset FRP" operation in Software. III. Write Full Combination Firmware. Go to "Developer Options" in phone Settings. Check "Enable OEM unlock" option. Make Factory Data Reset. Reflash the phone with full stock (orignal) firmware. Note: "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! If neither of these methods helps, or necessary files are missing, You can use Factory Reset FRP Service. |
