11-23-2016, 09:58 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | Samsung G930F frp remove [Solved] Samsung G930F cant remove frp Phone flashed with Combination FAC firmare When i try ResetFRP in software prog write own boot and after this phone freeze on logo (prog dont ask write or no, just write) 1. Why prog write this boot when i allready prepared phone with combination? 2. What version of this boot? Last edited by Octopus box; 11-29-2016 at 08:57. |
11-23-2016, 10:18 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. In latest Software version "Reset FRP/Reactivation/EE" operation writes Rooted Boot file to try to remove FRP lock. "Reset FRP" operation requires manual enabling of ADB. If You want to work with Combination firmware "boot.img", here are available methods: I.
II.
Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! |
11-23-2016, 12:11 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If "Enable OEM unlock" option is not available - You can try to use first method, or try to use different Combination firmwares. If neither of these methods helps - You can use Factory Reset FRP Service. |
11-28-2016, 23:22 | #5 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | Finally works after flashing this build http://forum.gsmhosting.com/vbb/f684...tions-2098508/ Just press Reset FRP via DM Thanx Octopus Team!!! |
