05-23-2017, 10:54 | #1 (permalink) |
No Life Poster Join Date: May 2016 Location: ...:::cAtCh mE iF U cAn:::...
Member: 2570477 Status: Offline Thanks Meter: 427 | Samsung G935F hang on logo Selected port: COM1 Selected model: SM-G935F Connecting to server... Connecting to server...Ok! Checking resource files... Downloading resources... All necessary resource files have been downloaded successfully. Please put the phone into Download Mode and connect USB cable. To put SM-G935F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Boot section... Boot section has been written successfully. Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server.timeout Phone not found. Operation was failed! Performed by 2.5.4 Software version. Last edited by Octopus box; 05-23-2017 at 12:13. |
05-23-2017, 11:05 | #2 (permalink) |
Member: 2570477 Status: Offline Thanks Meter: 427 | phone problem is FRP lock Octopus downloading 38mb file after download the file write to phone restart phone and stuck on the first logo please help octopus team |
05-23-2017, 12:02 | #3 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Quote:
If phone is stuck on logo - most likely it has one of the newer firmware. To return the phone to its initial condition You need to reflash it with an original firmware. To remove FRP lock You can try to write older (by release date) firmware, then repeat "Reset FRP/Reactivation" operation. Also You can use "Reset FRP" operation, but You will need a combination firmware that is compatible with current firmware of the phone, to enable ADB (http://forum.gsmhosting.com/vbb/f684...rrors-2189001/). There are two methods, of how to reset FPR using Combination firmware (to enable ADB): I.
II.
You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! | |
