11-24-2016, 06:41 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: INDIA Age: 36
Member: 1195083 Status: Offline Sonork: QQ:3208821449 Thanks Meter: 1,348 | SAMSUNG GALAXY J5 SM-J500F 6.0.1 NEW SEURITY FRP REMOVE With OCTOPUS NO NEED TO FLASH WITH COMBINATION NO NEED TO DOWNGRADE Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\23-11-2016_18-33-46.log" created (11/23/2016 6:33:53 PM). INFO : 11/23/2016 6:34:26 PM > Set up system language English (file: English.ini) INFO : 11/23/2016 6:34:26 PM > Welcome to Octoplus/Octopus Box Samsung software version 2.4.4 INFO : 11/23/2016 6:34:46 PM > ----------------------------------------------------------------------------------- INFO : 11/23/2016 6:34:47 PM > To connect SM-J500F phone you have to perform the following steps: INFO : 11/23/2016 6:34:47 PM > 1. Disconnect USB cable from phone. INFO : 11/23/2016 6:34:47 PM > 2. Go to Menu->Settings->More->About Device. INFO : 11/23/2016 6:34:47 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 11/23/2016 6:34:47 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 11/23/2016 6:34:47 PM > 5. Turn on "USB Debugging" option. INFO : 11/23/2016 6:34:47 PM > 6. Go to dial window. INFO : 11/23/2016 6:34:47 PM > 7. Enter "*#0808#" number. INFO : 11/23/2016 6:34:47 PM > 8. Select "DM+Modem+ADB". INFO : 11/23/2016 6:34:47 PM > 9. Press Home button. INFO : 11/23/2016 6:34:47 PM > 10. Press "Read Info" in software. INFO : 11/23/2016 6:35:35 PM > ----------------------------------------------------------------------------------- INFO : 11/23/2016 6:35:36 PM > Platform: Samsung Android INFO : 11/23/2016 6:35:36 PM > Selected port: COM1 INFO : 11/23/2016 6:35:36 PM > Selected model: SM-J500F WARN : 11/23/2016 6:35:36 PM > Connecting to server... INFO : 11/23/2016 6:35:42 PM > Connecting to server...Ok! INFO : 11/23/2016 6:35:42 PM > Checking resource files... INFO : 11/23/2016 6:35:44 PM > Resource files already downloaded. WARN : 11/23/2016 6:35:44 PM > Please put the phone into Download Mode and connect USB cable. WARN : 11/23/2016 6:35:45 PM > To put SM-J500F into Download Mode, You have to perform the following steps: WARN : 11/23/2016 6:35:45 PM > 1. Reconnect the battery. WARN : 11/23/2016 6:35:45 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 11/23/2016 6:35:45 PM > 3. When phone turns on, press "Volume+" key. INFO : 11/23/2016 6:35:45 PM > Waiting for phone... INFO : 11/23/2016 6:35:52 PM > Firmware write started. INFO : 11/23/2016 6:35:52 PM > Writing Custom section... INFO : 11/23/2016 6:35:58 PM > Custom section has been written successfully. WARN : 11/23/2016 6:35:58 PM > FRP lock is successfully reseted! BINF : 11/23/2016 6:35:58 PM > Wait 3-4 min then goto "Backup and reset" and make "Factory data reset" INFO : 11/23/2016 6:35:58 PM > Performed by 2.4.4 Software version. Last edited by Octopus box; 11-24-2016 at 08:49. |
The Following User Says Thank You to mr.luckytarun For This Useful Post: |
