10-13-2018, 09:10 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Croatia Age: 48
Member: 14602 Status: Offline Thanks Meter: 18 | Samsung Galaxy S8 Reset FRP need Combiantion [Answered] sw rev check fail bootloader device 3 or device 2 binary 1 in all cases any solution? or where can i find more combination firmwares Last edited by Octopus box; 10-13-2018 at 09:21. |
10-13-2018, 09:24 | #3 (permalink) |
Freak Poster Join Date: Jun 2016 Location: New ****** U.S.A
Member: 2590666 Status: Offline Thanks Meter: 130 | Download the right combination file with the right binary, to check the right binary from your phone, put the phone in download mode then check the following: "AP SWREV B:2 k:1 S:1 " that means is binary 2. So download combination binary U2-S2 etc.. and try again and post results. |
The Following 2 Users Say Thank You to yonic69 For This Useful Post: |
10-15-2018, 07:54 | #8 (permalink) |
Member: 14602 Status: Offline Thanks Meter: 18 | when i try to flash phone just boot i get write firmware failed also with whole comb file and i cannot flash phone when i try to flash full flash i get message please select firmware with pit till now i didn't need pit file |
10-15-2018, 17:09 | #10 (permalink) |
Member: 14602 Status: Offline Thanks Meter: 18 | i try some comb files from support but i cannot flash phone..can someone give me exactly firmware for flash this phone or comb firmware..i try several combination but without succes..i just need to remove frp COMBINATION_FA70_G950FXXU3ARG1_CL12792727_QB189982 88_REV00_user_mid_noship i try with this file |
10-15-2018, 17:10 | #11 (permalink) |
Member: 14602 Status: Offline Thanks Meter: 18 | Welcome to Octoplus Box Samsung software version 2.7.3 Selected AP file: M:\flesevi\sm-g950f\COMBINATION_FA70 _G950FXXU3ARG1_CL12792727_QB18998288_REV00 _user_mid_noship\COMBINATION_FA70_G950FXXU3ARG1 _CL12792727_QB18998288_REV00_user_mid_noship .tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G950F into Download Mode, You have to perform the following steps: 1. Power off the phone. 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Please select firmware with PIT Writing Firmware Failed Performed by 2.7.3 Software version. Selected AP file: M:\flesevi\sm-g950f\COMBINATION_FA70 _G950FXXU3ARG1_CL12792727_QB18998288_REV00 _user_mid_noship\COMBINATION_FA70_G950FXXU3ARG1 _CL12792727_QB18998288_REV00_user_mid_noship .tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G950F into Download Mode, You have to perform the following steps: 1. Power off the phone. 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.7.3 Software version. Selected AP file: M:\flesevi\sm-g950f\COMBINATION_FA70 _G950FXXU3ARG1_CL12792727_QB18998288_REV00 _user_mid_noship\COMBINATION_FA70_G950FXXU3ARG1 _CL12792727_QB18998288_REV00_user_mid_noship .tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G950F into Download Mode, You have to perform the following steps: 1. Power off the phone. 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Please select firmware with PIT Writing Firmware Failed Performed by 2.7.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G950F Operation: Reset FRP - ADB Searching for a phone (waiting for ADB device)...timeout Phone not found. Operation was failed! Performed by 2.7.3 Software version. Selected AP file: M:\flesevi\sm-g950f\COMBINATION_FA70 _G950FXXU3ARG1_CL12792727_QB18998288_REV00 _user_mid_noship .tar Please put the phone into Download Mode and connect USB cable. To put SM-G950F into Download Mode, You have to perform the following steps: 1. Power off the phone. 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Please select firmware with PIT Writing Firmware Failed Performed by 2.7.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G950F Operation: Read info Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.7.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G950F Operation: Read info Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.7.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G950F Operation: Read info Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.7.3 Software version. |
10-16-2018, 08:52 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | You need to use U3 Combination firmware, please http://forum.gsmhosting.com/vbb/f103...wares-2336370/. |
10-25-2018, 13:03 | #15 (permalink) |
Member: 14602 Status: Offline Thanks Meter: 18 | i manage to flash phone with comb file FA_70fxxu4ari1 i try to reset frp lock with frp reset over adb an everything wnt well sw succesfully reset frp an i do factory reset after but frp lock is still on after that i have problem with flashing read error pit i try on another computer and manage to revive phone with G950FXXU4CRI5_G950FODX4CRI7_CRO but still have frp lock on...how to remove frp lock i tried with octoplus samsung and octopus frp tool but nos result..both softwares said frp reset ok but frp lock is still on..anyone have right comb file for this s oftware G950FXXU4CRI5_G950FODX4CRI7_CRO |
