04-03-2015, 15:27 | #1 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1970633 Status: Offline Thanks Meter: 15 | Samsung gt-i8260 no network after repairing IMEI [Solved] the phone read simcard because ask for pin Now i'm trying to reflash any idea?? Last edited by Octopus box; 04-03-2015 at 16:21. |
04-03-2015, 15:32 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. Do the next: 1. Re-flas the phone. 2. Make Factory data reset and wipe cache partition. 3. Root the phone. 4. Make Unlock. 5. Make Repair IMEI. 6. Insett SIM card, wait 5-7 minutes and try to find and select network manually. 7. Write here the result. |
04-03-2015, 16:11 | #3 (permalink) |
Member: 1970633 Status: Offline Thanks Meter: 15 | Welcome to Octoplus/Octopus Box Samsung software version 1.8.9 ----------------------------------------------------------------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I8260 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM63 Selected model: GT-I8260 Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM17 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM32 Selected model: GT-I8260 Mode: Normal Phone model: GT-I8260 Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Jun 18 2014 Firmware released time: 20:12:57 Phone IMEI: 359826-05-70****-* SW version: 8X25-SSOSKOLYM-2035 ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM32 Selected model: GT-I8260 Mode: Normal Phone model: GT-I8260 Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Jun 18 2014 Firmware released time: 20:12:57 Phone IMEI: 359826-05-70****-* SW version: 8X25-SSOSKOLYM-2035 Unlocking phone... Phone is successfully unlocked ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM32 Selected model: GT-I8260 Port is busy Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM31 Selected model: GT-I8260 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM31 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM32 Selected model: GT-I8260 Mode: Normal Phone model: GT-I8260 Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Jun 18 2014 Firmware released time: 20:12:57 Phone IMEI: 359826-05-70****-* SW version: 8X25-SSOSKOLYM-2035 ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM32 Selected model: GT-I8260 Mode: Normal Phone model: GT-I8260 Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Jun 18 2014 Firmware released time: 20:12:57 SW version: 8X25-SSOSKOLYM-2035 Old IMEI: 359826-05-704569-7 New IMEI: 359826-05-706945-7 Searching for a phone. Please wait... Firmware compiled date: Wed Aug 13 19:22:54 KST 2014 PDA version: I8260XXANH2 CSC version: I8260ITVANH2 SW version: I8260XXANF1 Phone IMEI: 3598260570***** Phone SN: RF1F133HTMM Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Repairing network... Network is successfully repair. Repairing IMEI ... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) I'm waiting 7 minute (i reflash whit odin) Is Working Thx Octopus Team |
04-03-2015, 16:15 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Note, after repairing IMEI, to finish the "Repair IMEI" operation, You should restart the phone via phone's menu (via "Pover ON" button, don't disconnect the battery, this is important). |
