07-20-2013, 02:45 | #1 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1825943 Status: Offline Thanks Meter: 3 | Samsung GT-S7560M successfully unlock for more detailed info http://digitechmobilesolution.blogsp...rs-canada.html |
11-19-2014, 13:37 | #3 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Egypt Age: 40
Member: 58081 Status: Offline Thanks Meter: 10 | Its not unlocked GT-S7560M Platform: Samsung Anycall Selected port: COM95 Selected model: GT-S7560M Mode: Emergency Unlock for GT-S7560M phone in emergency mode can’t be done Last edited by Octopus box; 11-19-2014 at 13:49. |
11-19-2014, 13:50 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | "Mode: Emergency" means that phone was not configured for connection correctly. Please do the next: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Connect the phone directly to PC. 10. Press "Read Info" in software. |
11-19-2014, 14:08 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Yes, in order to perform "Unlock" operation You need to root the phone first. Try to use latest versions of VRoot or Kingo Root Software. |
11-19-2014, 15:17 | #8 (permalink) |
Member: 58081 Status: Offline Thanks Meter: 10 | Yes, in order to perform "Unlock" operation You need to root the phone first. Try to use latest versions of VRoot or Kingo Root Software. Thank you very much Its Successfully Unlocked After root by "Kingo Root Software" Thank you |
