06-04-2014, 22:04 | #1 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 567925 Status: Offline Thanks Meter: 15 | samsung i337 i have a samsung i337 that i repaired whith medusa, after that the phone did stay at logo, im tryng to flash it whith octopus but this is what i get Bienvenido en Octoplus/Octopus Box Samsung software versión 1.5.6 ----------------------------------------------------------------------------------- To connect SGH-I337 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Seleccione el archivo de firmware: I337UCUAMDB_I337ATTAMDB_I337UCUAMDB_HOME.oct Please switch your phone to the download mode and connect it to a PC. To put SGH-I337 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Escribiendo la sección ABOOT... L a sección ABOOT ha sido escrita con éxito Escribiendo la sección TZ... L a sección TZ ha sido escrita con éxito Escribiendo la sección BOOT... L a sección BOOT ha sido escrita con éxito Writing Firmware Failed the phone now say firmware upgrade encountered an issue pleas help me |
06-05-2014, 06:38 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to write other firmwares (with different Android versions), most likely, phone's boot loader doesn't allow to write this firmware. |
