Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 02-13-2015, 06:29   #1 (permalink)
Member: 1635037
Sonork: 1590479
Thanks Meter: 41
samsung i747M null imei
samsung i747 M null imei
I747MUMBLK3_I747MTCEBLK4_TCE_Android_4.1.1.oct
i flash this file
Please put the phone into Download Mode and connect USB cable.
To put SGH-I747M into Download Mode, You have to perform the following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" + "Home" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Found phone on
Firmware write started.
Writing ABOOT section...
ABOOT section has been written successfully.
Writing BOOT section...
Writing CACHE section...
CACHE section has been written successfully.
Writing MODEM section...
MODEM section has been written successfully.
Writing RECOVERY section...
RECOVERY section has been written successfully.
Writing RPM section...
RPM section has been written successfully.
Writing SBL2 section...
SBL2 section has been written successfully.
Writing SBL3 section...
SBL3 section has been written successfully.
Writing SYSTEM section...
SYSTEM section has been written successfully.
Writing TZ section...
TZ section has been written successfully.
Firmware writing successfully completed.
Old 02-13-2015, 06:55   #2 (permalink)
Member: 1635037
Sonork: 1590479
Thanks Meter: 41
Welcome to Octoplus/Octopus Box Samsung software version 1.8.3
To connect SGH-I747M phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "UART" radio button to "PDA" value.
8. Go to "Qualcomm USB Settings".
9. Select "DM+Modem+ADB".
10. Press Home button.
11. Go to dial window.
12. Enter "*#9090#" number.
13. Set "Diag config" to "UART" value.
14. Restart phone.
15. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM117
Selected model: SGH-I747M
Mode: Normal
Phone model: SGH-I747M
Firmware compiled date:
Firmware compiled time:
Firmware released date: -ù~
Firmware released time:
SW version:
Old IMEI: Unknown
New IMEI: 35022xxxxxxxxxx
Creating NVM backup
Reading NVM done!
Firmware compiled date: Sat Nov 24 10:59:36 KST 2012
PDA version: I747MUMBLK3
CSC version: I747MTCEBLK4
SW version: Unknown
Phone IMEI: Unknown
Phone SN: R21C8546MNZ
Android version: 4.1.1 (JRO03L)
Cheking Root
Reading security backup, please wait...
Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung
\BACKUP\Security-SGH-I747M-12-02-2015_22-51-42-.asec file
Erasing old IMEI. It can take some time. Please wait...
Phone will restart now. Please don't disconnect cable!
SW version:
Found phone on COM117
Repairing NVM for SGH-I747M phone...
Write IMEI failed
Old 02-13-2015, 08:23   #3 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,405
As You can see from your Software log, phone's modem part is damaged:
SW version: Unknown
This can be Software (modem firmware is damaged, or You have written unsuitable firmware) or HW problem.
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct), perform Repair IMEI operation. It is not possible to reapair IMEI, if phone's modem part is damaged.
Page generated in 0.16299 seconds with 8 queries
