10-21-2015, 14:54 | #1 (permalink) |
Major Poster Join Date: Feb 2014
Member: 2127503 Status: Offline Sonork: 100.16633951 Thanks Meter: 9 | samsung i8262 network problem [Solved] after flash with GT-I8262_for_IMEI_Repair_2.oct same problem Firmware compiled date: Apr 10 2013 Firmware compiled time: 03:00:00 Firmware released date: May 17 2013 Firmware released time: 18:17:33 SW version: 8X25-SSOSKOLYM-2035 Old IMEI: 004400-15-202000-0 New IMEI: 354xxxxxxxxxxx Searching for a phone. Please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed how to solve problem Last edited by Octopus box; 10-22-2015 at 13:47. |
10-21-2015, 15:03 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please make Factory Reset, then do the next: 1. Disconnect Micro USB cable from phone 2. Go to Menu->Settings->Applications->Development 3. Turn on "USB Debugging" option 4. When message is appear press "Yes" 5. Go to dial window 6. Enter "*#0808#" number 7. Set "USB" radio button to "MODEM" value 8. Go to "Qualcomm USB Settings" 9. Select "DM+Modem+ADB" 10. Go to dial window 11. Enter "*#9090#" number 12. Set "Diag config" to "USB" value 13. Connect the phone directly to PC. 14. Press "Read Info" in Octopus Samsung software. Keep phone's screen active and unlocked. Press "Ok" in any pop-up dialogues, which may appear on phone's screen during the operation. |
10-21-2015, 15:09 | #3 (permalink) | |
Member: 2127503 Status: Offline Sonork: 100.16633951 Thanks Meter: 9 | reply Quote:
all ready check all option but same problem | |
The Following User Says Thank You to faisal008 For This Useful Post: |
10-21-2015, 15:32 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try to Revoke USB debugging authorizations in Settings->Developer options. Try to reinstall Samsung USB drivers (http://octoplusbox.com/files/drivers...ile_Phones.exe) and restart PC. Try to use different USB ports of PC motherboard for connection. |
10-22-2015, 13:13 | #5 (permalink) | |
Member: 2127503 Status: Offline Sonork: 100.16633951 Thanks Meter: 9 | problem solve Quote:
problem solve To connect SCL24 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM9 Selected model: GT-I8262 Mode: Normal Phone model: GT-I8262 Firmware compiled date: Apr 10 2013 Firmware compiled time: 03:00:00 Firmware released date: May 17 2013 Firmware released time: 18:17:33 SW version: 8X25-SSOSKOLYM-2035 Old IMEI: 004400-15-202000-0 New IMEI: 354xxxxxxxxxxxxxx-x Searching for a phone. Please wait... Firmware compiled date: Fri May 17 13:34:15 KST 2013 PDA version: I8262XXAME8 CSC version: I8262OJVAME2 SW version: I8262JVAME1 Phone IMEI: Unknown Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Repairing network... Network is successfully repair. Repairing IMEI ... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM9 Selected model: GT-I8262 Mode: Normal Phone model: GT-I8262 Firmware compiled date: Apr 10 2013 Firmware compiled time: 03:00:00 Firmware released date: May 17 2013 Firmware released time: 18:17:33 SW version: 8X25-SSOSKOLYM-2035 Old IMEI B: 004400-15-202000-0 New IMEI B: 354xxxxxxxxxxxxxx-x Searching for a phone. Please wait... Firmware compiled date: Fri May 17 13:34:15 KST 2013 PDA version: I8262XXAME8 CSC version: I8262OJVAME2 SW version: I8262JVAME1 Phone IMEI: Unknown Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Repairing network... Network is successfully repair. Repairing IMEI ... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. | |
