01-23-2014, 20:52 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: FIND ME Age: 32
Member: 1538904 Status: Offline Sonork: 100.1603095 Thanks Meter: 198 | Samsung I8262 Test Moad(Yellow Screen) [Solved] Already Flashed 2 Different Flash File Imei Is OK,Network Ok, Original Imei Inside http://imagizer.imageshack.us/v2/800...0/163/3vfc.jpg http://imagizer.imageshack.us/v2/800x600q90/34/sujc.jpg http://imagizer.imageshack.us/v2/800...0/585/m543.jpg http://imagizer.imageshack.us/v2/800x600q90/21/j2pn.jpg Welcome to Octoplus/Octopus Box Samsung software version 1.4.6 ----------------------------------------------------------------------------------- To connect GT-I8262 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM109 Selected model: GT-I8262 Reading info, please wait... Detected phone model: GT-I8262 Firmware compiled date: Wed Jul 31 22:22:17 KST 2013 PDA version: I8262XXAMH1 CSC version: I8262ODDMH1 SW version: I8262DDMH1 Phone IMEI: 35569805xxxxxxxx Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Thank You Last edited by Octopus box; 02-19-2015 at 07:21. |
01-24-2014, 07:43 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. We will try to add solution of this problem in next updates. |
08-06-2014, 16:18 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Yes, Reset/Repair EFS for this device model will be added in one of the following Software updates. |
08-13-2014, 11:42 | #14 (permalink) | |
Freak Poster Join Date: Jul 2010 Location: Dharmapuri,Tamilnadu
Member: 1343981 Status: Offline Thanks Meter: 30 | try with below code it's will 100%% work Bro 1 ) Open DialPad 2 ) Dial On Screen *#87976633# 3 ) After Put This Code manually Restart Your Phone via Power Key Its Mine After restart your problem will solved Quote:
