01-28-2014, 07:24 | #1 (permalink) |
Junior Member Join Date: Jan 2012
Member: 1709512 Status: Offline Thanks Meter: 1 | Samsung i9100 flash ing problem ----------------------------------------------------------------------------------- To connect GT-I9100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. Selected firmware file: CODE_I9100XXLSJ.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9100 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing PIT section... PIT section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing DATAFS section... Writing Firmware Failed |
01-28-2014, 08:15 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please fully charge phone's battery, connect the device directly to motherboard USB port (don't use any USB hubs or USB PCI cards) and try to write firmware again. Try to write another firmware, try on another PC. |
