12-21-2014, 18:44 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Lahore
Member: 392149 Status: Offline Thanks Meter: 199 | Samsung i9210t can't work with Octopus i can't do anything with samsung i9210t can not read info, unlock, imei soft said phone not supporrted and auto model change in model list here is logs ----------------------------------------------------------------------------------- To connect GT-I9210T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM360 Selected model: GT-I9210T Mode: Normal Phone model: AAABQOCZ Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM361 Mode: Emergency |
12-21-2014, 18:49 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please connect the phone correctly. To connect GT-I9210T, carefully perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Press "Read Info" in software. Also try to select another COM port manually, set (mark) "Manual select" option in the Software and repeat the operation again. |
12-21-2014, 19:44 | #3 (permalink) | |
Member: 392149 Status: Offline Thanks Meter: 199 | Quote:
Welcome to Octoplus/Octopus Box Samsung software version 1.7.8 ----------------------------------------------------------------------------------- To connect GT-I9210T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM360 Selected model: GT-I9210T Mode: Normal Phone model: AAABQOCZ Warning: Selected model (GT-I9210T) differs from the detected one (AAABQOCZ)! Firmware compiled date: Nov 09 2011 Firmware compiled time: 09:00:00 Firmware released date: Apr 14 2012 Firmware released time: 16:18:27 Phone IMEI: 359629-84-894690-4 Phone was not found on the selected port! Last edited by Octopus box; 12-22-2014 at 07:12. | |
12-22-2014, 07:14 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
12-22-2014, 10:18 | #5 (permalink) | |
am also try to chek manual select but no luck could u plz chek on team viewer | |
12-22-2014, 14:27 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Yes, please contact us to Skype or ICQ right now, we will look remotely via Team Viewer, where can be the problem with your device. Our contacts You can find in our profile. |
12-23-2014, 09:11 | #7 (permalink) | |
for solution thank u | |
07-13-2016, 02:01 | #8 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | use UART 100% unlock Code: Welcome to Octoplus/Octopus Box Samsung software version 2.2.7 ----------------------------------------------------------------------------------- To connect GT-I9210T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: GT-I9210T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM119 Phone connection failed No diagnostic ports found! Connecting to phone on COM9 Phone connection failed Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: GT-I9210T Mode: Emergency Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM119 Phone connection failed No diagnostic ports found! Connecting to phone on COM9 Phone connection failed Selected action can’t be performed Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: GT-I9210T Mode: Emergency Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM119 Phone connection failed No diagnostic ports found! Connecting to phone on COM9 Phone connection failed Selected action can’t be performed Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM119 Selected model: GT-I9210T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM119 Phone connection failed No diagnostic ports found! Connecting to phone on COM9 Phone connection failed Selected action can’t be performed Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM119 Selected model: GT-I9210T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM119 Phone connection failed No diagnostic ports found! Connecting to phone on COM9 Phone connection failed Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM119 Selected model: GT-I9210T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM119 Phone connection failed No diagnostic ports found! Connecting to phone on COM9 Phone connection failed Selected action can’t be performed Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: GT-I9210T Mode: Emergency Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM9 Phone connection failed Selected action can’t be performed Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: GT-I9210T Mode: Normal Phone model: SCAQCSZQ Warning: Selected model (GT-I9210T) differs from the detected one (SCAQCSZQ)! Firmware compiled date: Jul 05 2012 Firmware compiled time: 23:00:00 Firmware released date: Jun 18 2013 Firmware released time: 13:49:56 Phone IMEI: 359629-04-073474-4 SW version: M9200B-SCAQCSZD-3.4.706063T Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.7 software version |
