11-10-2012, 20:41 | #1 (permalink) |
Insane Poster Join Date: Sep 2011
Member: 1646846 Status: Offline Sonork: 100.1615413 Thanks Meter: 16 | Samsung Galaxy S2 i777 Write firmware Done! ----------------------------------------------------------------------------------- To connect SGH-I777 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in Octopus Samsung software. Selected firmware file: I777UCKH7-REV02-home-low-CL503881.oct Please switch your phone to the download mode and connect it to a PC. To put SGH-I777 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume + " + "Volume -" buttons. 3. Insert usb cable. Found phone on Firmware write started. Writing SBL1 section... SBL1 section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing FACTORYFS section... FACTORYFS section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Firmware writing successfully completed. |
The Following User Says Thank You to darwin25 For This Useful Post: |
