06-01-2015, 18:53 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Madrid, Spain
Member: 591052 Status: Offline Sonork: 100.1592747 Thanks Meter: 95 | samsung i9301i imei repair i have Samsung i9301i with service imei now the phone is not getting network. so i have donwloaded the cert. from support with different imei. now its not writing the cert. here is log Welcome to Octoplus/Octopus Box Samsung software version 1.9.5 ----------------------------------------------------------------------------------- To connect GT-I9301I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9301I Reading info, please wait... ADB server killed. Detected phone model: GT-I9301I Firmware compiled date: Fri Jan 9 15:05:36 KST 2015 PDA version: I9301IXCUAOA1 CSC version: I9301IPHEAOA1 SW version: I9301IXXUANI2 Phone IMEI: 352607060137557 Phone SN: RV1FC1NR1FH Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9301I Selected file: E:\octupus\flas file\certificates\Cert-GT-i9301i_ 356650062371531_R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM8 Phone connected successfully Checking Certificate file... plz guide me how to write cert. |
06-02-2015, 07:12 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. In order to write Certificate file into GT-I9301I phone, You need to do the next: 1. Root the phone. 2. Perform "Wipe Security" operation. 3. Perform "Write Cert" operation. Try to write different Certificate files from the Support Area. Note: after "Wipe Security" operation phone's IMEI should become Unknown, then You will be able to write Certificate file. |
