03-30-2015, 10:31 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Try to write QCN from the Support Area, then re-start the phone, insert SIM card, wait 5-7 minutes and try to find and select network manually. |
03-30-2015, 10:37 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Try to do the next: 1. Re-flash the phone. 2. Make Factory data reset and wipe cache partition. 3. Root the phone. 4. Make Wipe Security. 5. Write IMEI Certificate from the Support Area. 6. Write QCN. 7. Re-start the phone, insert SIM card, wait 5-7 minutes and try to find and select network manually. |
03-30-2015, 10:40 | #7 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Onilne Mobile Technology
Member: 548479 Status: Offline Thanks Meter: 138 | thanks dear for replay Welcome to Octoplus/Octopus Box Samsung software version 1.9.0 ----------------------------------------------------------------------------------- To connect GT-I9301I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: GT-I9301I Please select service IMEI for this phone model Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: GT-I9301I Please select service IMEI for this phone model Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9301I Firmware compiled date: Tue Oct 28 18:47:03 KST 2014 PDA version: I9301IXCUANJ6 CSC version: I9301IITVANJ1 SW version: I9301IXXUANI2 Phone IMEI: Unknown Phone SN: RV1FB2A1CDP Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9301I-30-03-2015_14-58-55-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. 4. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM9 Phone connected successfully Writing new phone IMEI... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: GT-I9301I Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM9 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: GT-I9301I Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM52 Port is busy No diagnostic ports found! Connecting to phone on COM9 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: GT-I9301I Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: GT-I9301I Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM52 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9301I Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM55 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9301I Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM55 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM55 Selected model: GT-I9301I Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM53 Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 31 2014 Firmware compiled time: 12:00:00 Firmware released date: Sep 9 2014 Firmware released time: 16:34:00 Phone IMEI: 357537-06-406335-7 SW version: M8626A-AAAANAZM-1.0.4050 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM53 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 31 2014 Firmware compiled time: 12:00:00 Firmware released date: Sep 9 2014 Firmware released time: 16:34:00 Phone IMEI: 357537-06-406335-7 SW version: M8626A-AAAANAZM-1.0.4050 Repairing 3G/4G... Reading nv... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\NV-GT-I9301I-357537064063357-30-03-2015_15-11-20-.nv file 3G/4G repair successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM53 Selected model: GT-I9301I Reading info... Mode: Normal Firmware compiled date: Mar 31 2014 Firmware compiled time: 12:00:00 Firmware released date: Sep 9 2014 Firmware released time: 16:34:00 SW Version: M8626A-AAAANAZM-1.0.4050 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM53 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 31 2014 Firmware compiled time: 12:00:00 Firmware released date: Sep 9 2014 Firmware released time: 16:34:00 Phone IMEI: 357537-06-406335-7 SW version: M8626A-AAAANAZM-1.0.4050 Repairing 3G/4G... Reading nv... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\NV-GT-I9301I-357537064063357-30-03-2015_15-31-30-.nv file 3G/4G repair successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
