samsung i9305 imei repair issue please help. [Solved] i have samsung i9305 for imei repair(imei show 0/00) i have follow all instructions but no luck please help octopus box team. THANKS.. |
Hello. Make Repair EFS and then Repair IMEI and post the result here. |
Welcome to Octopus Box Samsung software version 1.9.2 ----------------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Close window. 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: GT-I9305 To put GT-I9305 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Repairing EFS... Searching for a phone. Please wait... EFS Repair successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM99 Selected model: GT-I9305 Mode: Normal Phone model: ACEFWMAZ Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM98 Mode: Emergency Write IMEI failed ----------------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Close window. 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM99 Selected model: GT-I9305 Mode: Normal Phone model: ACEFWMAZ Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM98 Mode: Emergency ----------------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Close window. 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM46 Selected model: GT-I9305 Mode: Emergency Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM46 Selected model: GT-I9305 Mode: Emergency Write IMEI failed please help:( |
Please select proper COM port, select (check) "Manual select." option and make Repair NVM and then make Repair IMEI. Post here full software log. |
Welcome to Octopus Box Samsung software version 1.9.2 ----------------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Close window. 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM99 Selected model: GT-I9305 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM98 Selected model: GT-I9305 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM46 Selected model: GT-I9305 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM46 Selected model: GT-I9305 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM98 Selected model: GT-I9305 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM99 Selected model: GT-I9305 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM99 Selected model: GT-I9305 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM98 Selected model: GT-I9305 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM46 Selected model: GT-I9305 Mode: Normal Phone model: Warning: Selected model (GT-I9305) differs from the detected one ()! Firmware compiled date: Firmware compiled time: Firmware released date: d Firmware released time: Incorrect IMEI SW Version: M9615ACEHWMAZD179535 Creating NVM backup Reading NVM done! Repairing NVM for GT-I9305 phone... NVM repair completed successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM46 Selected model: GT-I9305 Mode: Normal Phone model: ACEFWMAZ Warning: Selected model (GT-I9305) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Sep 07 2012 Firmware compiled time: 15:00:00 Firmware released date: Sep 24 2012 Firmware released time: 09:38:16 SW Version: M9615ACEHWMAZD179535 Old IMEI: 004400-15-202000-0 New IMEI: 350xxx-xx-xxxxxx-x New IMEI successfully written. Please, restart the phone to apply changes thanks to octopus support team BR jindalgsm |
