Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 05-12-2013, 01:31   #1 (permalink)
JINDALGSMô's Avatar
Member: 467045
Sonork: 100.1603919
Thanks Meter: 1,706
samsung i9305 imei repair issue please help. [Solved]
i have samsung i9305 for imei repair(imei show 0/00) i have follow all instructions
but no luck please help octopus box team.
THANKS..
Old 05-12-2013, 11:05   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 20,705
Hello.
Make Repair EFS and then Repair IMEI and post the result here.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 05-12-2013, 11:45   #3 (permalink)
JINDALGSMô's Avatar
Member: 467045
Sonork: 100.1603919
Thanks Meter: 1,706
Welcome to Octopus Box Samsung software version 1.9.2
To connect GT-I9305 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Developer options.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "USB" radio button to "MODEM" value.
8. Go to "Qualcomm USB Settings".
9. Select "RNDIS+DM+MODEM".
10. Enter "*#9090#" number.
11. Select DM/DUM over HS-USB.
12. Close window.
13. Go to dial window.
14. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM7
Selected model: GT-I9305
To put GT-I9305 phone into download mode you have to perform the
following steps:
1. Reconnect phone battery.
2. Press and hold "Volume - " + "Home" + "Power" buttons.
3. When phone turns on press "Volume+" button.
Repairing EFS...
Searching for a phone. Please wait...
EFS Repair successfully
Selected port: COM99
Mode: Normal
Phone model: ACEFWMAZ
Phone model is not supported
Phone was not found on the selected port!
Searching for USB diagnostic port...
Connecting to phone on COM98
Mode: Emergency
Write IMEI failed
12. Close window.
Mode: Normal
Mode: Emergency
12. Close window.
Selected port: COM46
Mode: Emergency
Write IMEI failed
Mode: Emergency
Write IMEI failed
please help
Old 05-13-2013, 08:20   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Please select proper COM port, select (check) "Manual select." option and make Repair NVM and then make Repair IMEI. Post here full software log.
Old 05-13-2013, 10:24   #5 (permalink)
JINDALGSMô's Avatar
Member: 467045
Sonork: 100.1603919
Thanks Meter: 1,706
problem solved
12. Close window.
Selected action canít be performed
Selected port: COM98
Mode: Normal
Phone model:
Warning: Selected model (GT-I9305) differs from the detected one ()!
Firmware compiled date:
Firmware compiled time:
Firmware released date: d
Firmware released time:
Incorrect IMEI
SW Version: M9615ACEHWMAZD179535
Creating NVM backup
Reading NVM done!
Repairing NVM for GT-I9305 phone...
NVM repair completed successfully
Please, restart the phone to apply changes
Mode: Normal
(ACEFWMAZ)!
Firmware compiled date: Sep 07 2012
Firmware compiled time: 15:00:00
Firmware released date: Sep 24 2012
Firmware released time: 09:38:16
Old IMEI: 004400-15-202000-0
New IMEI: 350xxx-xx-xxxxxx-x
New IMEI successfully written.
thanks to octopus support team
jindalgsm
The Following User Says Thank You to JINDALGSMô For This Useful Post:
Page generated in 0.23477 seconds with 7 queries
