01-20-2015, 07:08 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Sky Mobile™
Member: 1049764 Status: Offline Sonork: 100.1678585 Thanks Meter: 62 | samsung i9500 flashing fail [Solved] ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: I9500XXUFNB3_I9500SERFNB3_SER_Russia_Android_4.4.2 .oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... Writing Firmware Failed Last edited by Octopus box; 01-20-2015 at 15:38. |
01-20-2015, 08:28 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. What is the problem with your device? What is the state of your device exactly? Why do You want to write another firmware. To write firmware, fully charge phone's battery, connect the phone directly to PC motherboard USB port (don't use any USB hubs or PCI USB extention cards, this is important) and try to write firmware again. Try to write other firmwares. Try to write firmwares on another PC. Also, check, whether KNOX is anabled in your device. |
01-20-2015, 09:35 | #3 (permalink) |
Member: 1049764 Status: Offline Sonork: 100.1678585 Thanks Meter: 62 | try to unlock after unlock imei is null after re flash get this error plz help. now phone in samsung logo Last edited by naazerkhan; 01-20-2015 at 09:40. |
01-20-2015, 10:16 | #4 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR allumts | |
01-20-2015, 11:03 | #5 (permalink) |
Member: 1049764 Status: Offline Sonork: 100.1678585 Thanks Meter: 62 | try another pc and with another firmwear but same error .Writing Firmware Failed 99% get this error what can i do.. now phone in (firmware upgrade encountered an issue.please select recovery mode in kies & try again) |
01-20-2015, 11:27 | #6 (permalink) | |
Use Last Original Stock FW for you country, not other, Download from Sam mobile or Samsung Updates, (remove space in link), try flashing with Odin +PIT and post Log, if any partition is damaged is obvius that Flash stopping... | |
