11-06-2014, 18:25 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | samsung i9500 imei repair imei null/null Connecting to phone on COM16 Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Phone connection failed No diagnostic ports found! Connecting to phone on COM179 Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: GT-I9500 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: GT-I9500 Detected phone model: GT-I9500 Firmware compiled date: Wed Aug 6 16:29:31 KST 2014 PDA version: I9500XXUGNH2 CSC version: I9500OJVFNG1 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9500-Unknown06-11-2014_22-11-17-.asec file Cheking security type... New security type is detected Executing exploit... Exploit has been executed successfully Old IMEI: Unknown New IMEI: 352993-05-004445-2 Repairing IMEI ... Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now IMEI successfully repaired. Please, restart the phone to apply changes |
The Following User Says Thank You to maplegsm For This Useful Post: |
11-06-2014, 18:28 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. As You can see from your Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair EFS" and "Repair IMEI" operations. It is not possible to repair IMEI, if phone's modem part is damaged. | |
11-07-2014, 15:28 | #3 (permalink) | |
Freak Poster Join Date: May 2013 Location: Turkey
Member: 1941192 Status: Offline Thanks Meter: 57 | Quote:
What is the name modem that he should put it? | |
11-07-2014, 15:30 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | You should write different firmwares one by one and check, whether modem (baseband) is correct (SW version in log not Unknown). |
11-09-2014, 09:49 | #6 (permalink) |
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | octopus cant same problem after successfully repaired Welcome to Octoplus/Octopus Box Samsung software version 1.7.4 ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: GT-I9500 Port is busy Searching for a phone. Please wait... Please, press "OK" button on the phone to allow USB debugging.. Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM23 Port is busy No diagnostic ports found! Connecting to phone on COM179 Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Searching for a phone. Please wait... Phone found. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: GT-I9500 Port is busy Searching for a phone. Please wait... Please, press "OK" button on the phone to allow USB debugging.. Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM23 Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Phone connection failed No diagnostic ports found! Connecting to phone on COM179 Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: GT-I9500 Port is busy Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM23 Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Phone connection failed No diagnostic ports found! Connecting to phone on COM179 Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: GT-I9500 Port is busy Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM23 Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Phone connection failed No diagnostic ports found! Connecting to phone on COM179 Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Searching for a phone. Please wait... Found more than one suitable android devices. Please, disconnect all devices except one and repeat the procedure. Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: GT-I9500 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: GT-I9500 Detected phone model: GT-I9500 Firmware compiled date: Wed Jun 4 10:18:03 KST 2014 PDA version: I9500ZSUDNF1 CSC version: I9500OZSDNF1 SW version: I9500XXUGNE3 Phone IMEI: 359169053230033 Phone SN: R21DB9HZNVE Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9500-Unknown09-11-2014_00-36-02-.asec file Cheking security type... New security type is detected Executing exploit... Exploit has been executed successfully Old IMEI: 359169-05-323003-3 New IMEI: 357666-89-789789-5 Repairing IMEI ... Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now IMEI successfully repaired. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: GT-I9500 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: GT-I9500 Detected phone model: GT-I9500 Firmware compiled date: Wed Jun 4 10:18:03 KST 2014 PDA version: I9500ZSUDNF1 CSC version: I9500OZSDNF1 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9500-Unknown09-11-2014_00-42-28-.asec file Cheking security type... New security type is detected Executing exploit... Exploit has been executed successfully Old IMEI: Unknown New IMEI: 352993-05-004445-2 Repairing IMEI ... Repairing network. Please wait, this can take some time... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Network is successfully repaired Phone will restart now IMEI successfully repaired. |
11-09-2014, 10:36 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | If after of repeairing IMEI/Network or unlocking, phone's modem part becomes Unknown, this means there is new CPU Bootrom in your device (please look here: http://forum.gsmhosting.com/vbb/f684...i9500-1751585/). It is not possible to write any IMEI You want. You have two possibilities - try to write one of the service's IMEIs from the Software list or write the certificate with new IMEI. To write Service IMEI, do exactly the next: 1. Take out SIM and SD cards from the phone. 2. Re-flash the phone with the same Android firmware version, that is in your phone. 3. Make Repair IMEI (write service IMEI from the Software list, not any IMEI). 4. Re-flash the phone again. Also, look here: http://forum.gsmhosting.com/vbb/f684.../#post10321348 http://forum.gsmhosting.com/vbb/f684.../#post10322791 http://forum.gsmhosting.com/vbb/f684.../#post10333528 To write IMEI from the Cert file, do exactly the next: 1. Take out SIM and SD cards from the phone. 2. Re-flash the phone with the same Android firmware version, that is in your phone. 3. Make Factory data reset and wipe cache partition. 4. Root the phone. 5. Make Wipe Security ("Repair Security/Wipe Security" button in the Software). 6. Write Certificate (https://mega.co.nz/#!TxJhyYCQ!K4IM67...TReLJbM7Mk0W2U). Post here the result. |
