09-24-2014, 11:34 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Lahore
Member: 392149 Status: Offline Thanks Meter: 199 | samsung i9505 after flash not work [Solved] system software not authorized by samsung has been found on your phone am also try many files from support erea with diffrent files like 4.4.2 4.2.2 but not luck befor flash phone's version is 4.2.2 Last edited by Octopus box; 09-27-2014 at 16:36. |
09-24-2014, 11:41 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Quote:
09-24-2014, 11:53 | #3 (permalink) | |
Member: 392149 Status: Offline Thanks Meter: 199 | Quote:
what firmware write before and here is another case http://forum.gsmhosting.com/vbb/f684...olved-1712674/ | |
09-26-2014, 12:31 | #8 (permalink) | |
here is logs Selected firmware file: I9505XXUDMH8 _I9505OXXDMHA_BTU_Android_4.2.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9505 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing SBL1 section... SBL1 section has been written successfully. Writing SBL2 section... SBL2 section has been written successfully. Writing SBL3 section... SBL3 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing PERSDATA section... PERSDATA section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MDM section... MDM section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. | |
09-26-2014, 12:35 | #9 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Quote:
wipe data and cache................... | |
09-26-2014, 12:38 | #10 (permalink) | |
Freak Poster Join Date: Jun 2012 Location: GSM Philippines
Member: 1778770 Status: Offline Thanks Meter: 109 | Quote:
