07-09-2014, 14:42 | #1 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 838176 Status: Offline Thanks Meter: 57 | samsung i9505 unlock problem log file Welcome to Octoplus/Octopus Box Samsung software version 1.6.1 ----------------------------------------------------------------------------------- To connect SC-01C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: Root_GT-I9505_new.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM5 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM5 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9505 Mode: Emergency Codes for GT-I9505 phone in emergency mode can’t be read Reading codes canceled ----------------------------------------------------------------------------------- |
07-09-2014, 15:01 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please look here: http://forum.gsmhosting.com/vbb/f684.../#post10292878, http://forum.gsmhosting.com/vbb/f684.../#post10364431, http://forum.gsmhosting.com/vbb/10257898-post1505.html. To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. |
07-09-2014, 15:14 | #3 (permalink) | |
Member: 838176 Status: Offline Thanks Meter: 57 | Quote:
sir this handset versio 4.3 | |
07-09-2014, 15:16 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | This doesn't matter. 1. Root the device manually. 2. Disable KNOX (if it is active). 3. Write firmware "GT-i9505_for_Unlock_and_IMEI_repair". 4. Perform Unlock operation. 5. Write here the result. |
