09-18-2015, 11:35 | #1 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Mandaue City, Cebu
Member: 1986646 Status: Offline Thanks Meter: 100 | Samsung J1 SM-J100ML zero IMEI repair (Tested Root File) Root using Perma Root. Must be connected to Wifi Copy Perma Root APK to phone, enable unknown sources, install apk then run application https://mega.nz/#!thpg3C6I!mmoMAM9cs...LJLiZrNAkWxE7U Enable USB Debugging Dial *#0808# choose DM+Modem+ADB Connect to PC Open Octopus, Choose exact model, back up the Security, EFS and QCN Choose IMEI Repair. Allow USB Debugging and Root Access Repeat repair for sim 2 IMEI |
The Following 2 Users Say Thank You to freesoul22 For This Useful Post: |
11-12-2015, 10:33 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to root the phone with application, suggested by mr. freesoul22. Also, try to use latest versions of IRoot and Kingo Root, to root the phone. |
12-30-2015, 10:16 | #4 (permalink) |
No Life Poster Join Date: May 2010 Location: Samsung Mobile Philippines
Member: 1300241 Status: Offline Sonork: 100.1626973 Thanks Meter: 356 | do you have back-up EFS, QCN, & also cert for this model sir? can you pls share it here... i have also face this kind of problem. tia. |
The Following User Says Thank You to Asia_Phone For This Useful Post: |
